Apple iPad (16 GB) WiFi Tablet PC Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipad won't turn on
Hey there
My new Ipad won't turn on, I used it last night and then left it with the charger for the rest of the night, now I've tried to turn it on and it won't work.
Any idea how to repair this?
I think since it's working on the same OS as the iPhone then the usual solution for the iphone should work also here but I want to be sure before I do it.
Thanks
  • Anonymous Mar 15, 2014
    IPhone & iPad VPN has to be re-started every time you start it...why?
Tim Digibrain
Level 3:
  • Master 846 Answers
  • Posted on Apr 26, 2010
Tim Digibrain
Master
Level 3:
Answers
846
Questions
0
Helped
1310070
Points
1356
Hold the on switch and menu button together for a hard reset. If you can reset it, there may be an issue with your motherboard. If apple doesn't replace it for you, You can get the board at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on Dec 14, 2010
Anonymous
Expert
Level 2:
Answers
94
Questions
0
Helped
52738
Points
284
The reason may be that your iPad is no electricity. Your should charge.
But you should notice that the iPad can't run off AC power alone so it has to charge the battery a certain amount before it'll turn on.
If not, Also - the charger can go bad on these things, and the cord can go bad.
also, you may find aswer on this page.
http://www.apple.com/support/ipad/
Thanks for your interest in fixya please do be considerate to leave positive feedback and ratings for me if you feel my answer have helped you. Thank you. Aneesoft iPad converter suit.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5443
Points
Fully charged Ipad does not switched on. Please help
MY i pad will not charge
As soon as you connect your iPad to a working charger, it will beep. If you plug in the cable and you don't hear the beep, assume something is wrong. Just find out what, the cable or the charger.
Don't try to charge the iPad with a computer, because the 500 mA a USB connector from a computer can give, is not enough even to start.
But you can use a computer to test the cable, because the iPad should beep and say on the screen not charging.
If there is no beep when connecting to a computer, you have to use another cable. If it beeps, buy a new charger. 5 Volt 2 A. The best an Apple charger.
tip
Heck, we all have problems....simple or huh? ?well, last night when I turned on...
  1. Heck, we all have problems....simple or huh?
well, last night when I turned on the computer it was all screwed up....said do this, do that. I was furious wanted my main page and icons....I tried all they said to do.....half hour at least....then I remembered then I had simple problems before would turn off computer and voila all ol....last night held Heck, we all have problems....simple or huh?
well, last night when I turned on the computer it was all screwed up....said do this, do that. I was furious wanted my main page and icons....I tried all they said to do.....half hour at least....then I remembered then I had simple problems before would turn off computer and voila all ol....last night held down both buttons for at least five minutes...maybe more.....was sure it was going to be an Apple problem....aha, the apple appeared:). Took long time to refresh...but all was there, icons and all! Paid myself ten bucks.....all is fine today, thought I would share....so there you have it...hope it helps? All other things were minor.....not this one.
My ipad is not charging at all has been completely dead & when i plug it in has a plug picture what can i do?
Are you using the 5 volt 2.1 amp charger. The ipad won't charge with out this charger.
1helpful
Cabel not working.
It is possible that either the iPad or the charger is fake; there are many manufacturers that make bootleg tablets and chargers.
If you are sure that the product is not fake, bring the iPad and charger to the nearest Apple store or Authorized Reseller for inspection.
Ipad only charging to 30% overnight
Might be a faulty charging cable I'd suggest buying a new one , also never let the battery run completely dead plug it in before it goes off .
1helpful
Ipad won't turn on. Worked fine last night, got down to about 5% battery left. Plugged in overnight and it won't turn on. Tried different power cables, no success. Tried plugging into PC no luck. ...
You could try a hard reset.
Hold down the power button and the home button at the same time until the device completely shuts down and the Apple logo appears.
Hope that helps!
I bought a mini apple ipad in LA last night and I am at home trying to use it. how do I start?
I love tips and tricks manuals But get online first Find you tube and stream your self some answers!!!!!
6helpful
2answers
Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
1helpful
IPad HD loses battery power quickly. How can I make sure my iPad has enough battery life?
Here are things that help.
  • Turn down screen brightness
  • Don't play graphics heavy games
  • Turn off location services
  • Quit applications you are not using
  • Turn off push notifications
  • Set email to manual update
  • Don't use 4G internet connection if possible
For charging do these things.
  • Use charger that came with the new iPad
  • Don't charge with USB outlet on computer always plug into a wall
3helpful
3answers
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
