How do I watch a dvd movie on tv? I have the dvd player hooked up and movie is playing but I don't know how to get to the channel for the movie
If you have connected the DVD player to the TV set's audio/video input jacks, you need to switch to those inputs using the remote control. Most RCA/GE brand sets don't have a way to do that from the front panel menu buttons. If you are using a universal replacement remote, it may not have a button that works to switch inputs. If that's the case, try an RCA or GE brand universal remote that has an "input" button. That may work.
If you can't get the player working through the set's AV jacks, you can use an RF converter. This device takes the DVD player audio and video and converts it to a channel 3 or 4 (RF) signal that you can tune in on the set. Converters are around $20. You won't get full picture and sound quality with this arrangement, though.
Hope this helps. Thanks for using Fixya!
Press the av or au bullon on remote until you get to the dvd "channel"
SOURCE: no signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
SOURCE: I don't know what channel the tv is supposed to be on
Hello, you set your TV for channel 3 or 4, if your combo has an out to TV RF connector(threaded connector) or you set the TV for video 1or video 2 if it has the RCA video/audio outs in the rear. If the TV has no auxiliary jacks you will need an RF converter, usually common in any electronics store(radio shack or similar).
