yes my mms settings are ok but only my sms i cant sendyes my mms settings are ok but only my sms i cant send
AnonymousMar 14, 2014
I received messages delay and send it long time before it sends sometimes it tells resend.I received messages delay and send it long time before it sends sometimes it tells resend.
You can't post conmments that contain an email address.
The settings are all different, Internet, Wap etc... for MMS you need to call your service provider and ask them to send you the MMS settings, they are sent via a txt msg, when you receive them click Save or Install.
MMS doesn't work between all networks.
with an MMS-enabled phone you can: Take digital photographs and store photographs on the Internet Send and receive full colour pictures Send and receive voice clips Add a text message to your picture Purchase pictures and sounds from the Internet Have enhanced polyphonic ringtones MMS runs over GPRS. You normally need to subscribe to a GPRS tariff, and have 'Media Messaging' enabled by your network operator. You will need a phone handset that supports the MMS service - If you receive an MMS message and don't have a suitable handset or GPRS service, you'll receive a standard SMS text message, and will be able to view the message at the web address included with the text message.
Hi friend
i saw that many people have problem about there mms and internet settings.
so i try to colect the settings of mms and internet of some networks which are use
around the world. i arrange them by the country name so select your country and get your mms and
internet settings
<br />
<br />
1.> PAKISTAN
<span> </span>>UFONE
<span> </span> You can get MMS & GPRS settings for your handset by;
<span> </span>Sending your phone's model number in an SMS to 222
<span> </span>Example: P910i or 6600 or razr v3
<span> </span> <span> </span>Or by calling/visiting our Customer Services Centers. To call from your
<span> </span>Ufone connection simply dial 333. To call from a PTCL landline, dial 111-333-100.
<span> </span>Usage Charges:
<span> </span>The cost of sending an MMS is Rs. 5.00
<span> </span>The cost of receiving an MMS is Rs. 5.00
<span> </span>Note:
<span> </span>GPRS and MMS activation is FREE for all Prepay and Postpay users.
<br />
<br />
<span> </span>>MOBILINK
<span> </span>Activate your GPRS & MMs connection now by calling 111
<br />
<span> </span>>Telenor
<span> </span> .VIA sms
<span> </span> Send a text message to 131 with your handset make and model to receive your handset settings:
<br />
<span> </span>For Example:
<br />
<br />
<span> </span>For Internet
<span> </span> Write "Internet" and SMS it to 131.
<br />
<span> </span>For WAP
<span> </span> Write "wap" and SMS it to 131.
<span> </span>For MMS
<span> </span> Write "mms" and SMS it to 131.
<br />
<span> </span> For All handset setting
<span> </span> Write "All" and SMS it to 131.
<br />
<span> </span>.MANUAL
<br />
You can also configure your handset for GPRS & MMS manually:
1. Configuration for WAP
<span> </span>
Access Point Name/Node<span> </span> wap
<span> </span>
Login name<span> </span> Telenor
<span> </span>
Password<span> </span> Telenor
<span> </span>
WAP Gateway IP<span> </span> 172.18.19.11
<span> </span>
Port (if required)<span> </span> 9201
<span> </span>
Port (if required for HTTP handsets)<span> </span>8080
<br />
2. Configuration for MMS
<span> </span>
Access Point Name/Node<span> </span> mms
<span> </span>
<span> </span>
<span> </span>
<span> </span>
<span> </span>
<span> </span>
Relay Server/ Messaging Server<span> </span> http://mmstelenor
or
http://172.18.15.1
<br />
<br />
.VIA CALL
You can also dial 345 from your Telenor Mobile subscription and
<span> </span> our staff will help you configure your handset for GPRS settings.
>WARID
<br />
please call Warid helpline 321 or visit out Business Centers to avail this service.
<br />
<br />
>ZONG
To activate MMS send the following command;
MMS <space> handset <space> model & sms to 131
<br />
1. Open up the main menu (by pressing the centre button) and navigate down to "MESSAGING" 2. Find the MMS message that you are trying to open 3. Click on it with the "OK" key, and it should prompt you to donwload it. 4. Click "yes" and the MMS should be displayed
You must have access to internet on your mobile device or this process may not work.
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
Hi, sending and receiving of text messages, MMS and internet service has to do with the network setting provided by your network provider.
Your network provider has to send you different settings for your internet connection and your MMS connection and since you cannot receive MMS, you have to contact your service provider through their help line or toll free line to make a request for the MMS settings and it will be sent to you before you can start receiving MMS..
hi there, You need to contact the helpline number of your network operator and ask them for the settings.they will send you the settings save it and activate it as default in your mms settings. please vote me if i had helped.
Do you want to sent mms/sms. for sending mms you need to suscribe from your operator and save mms settings on your mobile.
For sms check your message center number with your network provider and input the number in your message setting option.
