LG BH100 Blu-Ray Disc Player Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The remote control code number 21268 given for Insignia NS-WBRDVD does no work. I need the correct code to program my hand held control of my Toshiba 47ZV650U TV
Anonymous
Level 2:
Champion:
  • Expert 312 Answers
  • Posted on Jul 02, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
312
Questions
0
Helped
126426
Points
418
If the provided code does not work, you must use the scan or learning feature of your universal remote control to find a workable code.
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
Remote control not recognizing codes
Codes for many of our TVs can be found at InsigniaProducts.com. For the Blu-ray player, we recommend using your universal remote's scan or learning feature.
4helpful
Do not know the activation code for the NS-WBRDVD Insignia Blue Ray from Best Buy. Cannot streamline Netflix without it??
To stream Netflix content you will need to have a computer connected to the internet and a netflix account (even the lowest level should allow you access).
Set your NS-WBRDVD to connect to your wireless network.
Start up Netflix and select you are a new user. You will be given an activation code.
On your computer, log-in to the Netflix website: www.netflix.com On the top right of the screen you should see "Your Account & Help" Click that.
On the "Your Account & Help" screen, in the Account Information section on the bottom right of that grayed box should be "Add Blu-Ray". Click that and you should be prompted to enter the code your NS-WBRDVD gave you.
Once you enter the code and Netflix accepts it, your player should confirm and allow you to watch Netflix streaming content.
Hope this helps!
I need to program a universal remote, a ge modal249 my Insignia modal NS-DXA1-APT digital analog converter [email protected]
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control our converter.
2answers
Onkyo remote code for Insignia Blu-Ray?
Unfortunately, Insignia can't provide a code. We recommend using your universal remote control's scan/learning feature to find a compatible code.
2answers
Need DirecTV universal remote code for Insignia NS-DXA1 converte
Most universal remote controls have a scan feature to find a code where one is not available. If this process doesn't work, additional assistance may be found at Community.InsigniaProducts.com.
1helpful
9helpful
5answers
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
