Question about Audiovox SMP-2GBL (2 GB) MP3 Player
How do you turn it on? darn thing didn't come with a manual, i already input the triple AAA batteries and pressed all the buttons.
    New Friend:
Of the 4 buttons on the side, push and hold the extreme right button until it turns on...same to shut it off
Posted on Mar 13, 2010
6ya staff
SOURCE:
I bought this control and threw out the manual I didn't realize I needed one it's model no: URC 11-2981 R00 Anyone know how I can use it
Hi Please check the have you inserted 2 battaries (AAA
(x2)).
Search method:
1) Press TV button.
2) Press Magic button and hold for 3 secs
3) Now press 991
4) now press power button
5) now press CH+ button until your television turns off. This may need to press many times.
6) Once turns off, press magic button.
7) Now press Power button. some times TV may not turn on, at that time press any other button.
Volume Lock:
1) Press magic button and hold for 3 seconds
2) press 993
3) press TV Key.
If you require more option please post which option require to you.
Feb 10, 2013 | Televison & Video
Cant use my fv700 i changed the chanell and frequency for bothh but still not working help
One solution that i read was "i had two fv700 do the same thing. i replaced the nimh battery packs in both radios and replaced with triple a batteries and both started working properly"
This has worked for me also - aaa batteries fit right in - it's just a drag that it's not rechargeable anymore - I wonder if 3 rechargeable aaa's would work?
Hope this works!
Jul 28, 2011 | Radio Communications
Battery on a 2005 Mustang went dead. Had a Jump to get the car started. Drove & speedometer & odometer worked fine. However, I had Triple AAA install a new battery & now they don't work. ...
Did AAA clean the battery cable connections when they installed your battery? Did you check the fuse for the insrument panel?
It could be just bad timing or a coincidense but I am more likely to think things are connected. If your gauges worked after jump starting your car, but not after AAA changed the battery, something changed or was left disconnected.
Jul 03, 2011 | 2005 Ford Mustang
My screen turns on but when you do anything it has random numbers, line and letters on it and i need to get it fixed immediatley
I've had this issue before with my TI-83 Plus. I'm not sure exactly the solution I used, but these steps progress through the mildest to most extreme methods of fixing the calculator.
Solution 1: Take the batteries out.
Odds are you've tried this already, but it bears mentioning.
With the calculator on, remove the triple A batteries housed in the back. After a few seconds, replace them and turn the calculator on.
Solution 2: Clear the RAM.
Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
Solution 3: Reinstall the operating system
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now"
Here is the website to reinstall your OS. First you'll need the TI-Connect software.
Solution 4: Remove all sources of power. This is a risky move, but if your calculator will absolutely not work after you try even reinstalling the operating system, it might be your last hope.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
May 12, 2011 | Texas Instruments TI-83 Plus Calculator
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
Janome Harmony 2049
Darning would normally be done with the triple stretch stich, the one that is a zig-zag broken up into three stitches right and then three stitches left. See-through Zig-Zag foot. Zig-Zag set at it's widest. Feed set to about 1/16-1/8 inch (1.5-3mm) and darn by sewing forward a bit, adjust fabric, and then backward by pressing and holding the reverse button. Continue back and forth until you've created a darned box. For extra strength, turn fabric 90 degrees and repeat over same area.
Jan 29, 2008 | Janome 2049LX Mechanical Sewing Machine
TI82 does not graph correctly
My best advice is to go to Window then Format menu and make sure your axes are on. Or press 2nd then up arrow and hold it untill it is visible (if you go too dark do the same thing just with the down arrow.
Jan 17, 2008 | Texas Instruments TI-82 Calculator
Ti 83
Remove one of the AAA batteries. Press and hold CLEAR while reinstalling the AAA battery. Continue holding CLEAR button and press ON. Release buttons and press CLEAR again.
Jan 02, 2007 | Texas Instruments TI-83 Plus Calculator
Audiovox SMP-2GBL (2 GB) MP3 Player Logo
99 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Ekse
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
