Question about Frigidaire GLTF1240A Front Load Washer
Washing machine leaking water under neith - Frigidaire GLTF1240A Front Load Washer
  • 6 more comments
  • Anonymous Feb 24, 2008
    I just bought a new Whirlpool top loading washer with large stainless tub about two weeks ago. After working 6 days per week, I came in last evening and started washing clothes. During the spin cycle I heard a loud sound of rushing water. When I immediately looked at my floor and it was flooded! On kitchen carpet at that! You can imagine the mess and my irritation! The hoses were connected and all water came from underneath the washer. Of course it is the week end and you have to wait with a tub of wet clothes until a repairman can be reached. After reading about the stains on clothes from the stainless tub and the problem with the water, I really wonder if my purchase was a very bad choice.
  • Anonymous Jun 05, 2008
    Water leaking from bottom of washing unit.
  • gardencat Jul 31, 2008
    My washing machine is 4 years old. When the water is going INTO the washer it is dripping on the floor from underneath the machine. The entire bottom of the washer is rusted out. Can this be fixed or do I need a new washing machine. It is a Kenmore Elite from Sears. I do not have an extended warrantly. I have taken no steps to fix this. I wouldn't even know where to begin.
  • ronrosse1014 Aug 05, 2008
    water leaking underneath the washer. extended warranty is over after 5 yrs, my washer is about 6 yrs old. i need some help where to start and where to check the water leak.
  • Anonymous Aug 05, 2008
    cabrio top loader leaking water from underneath from some sort of pump it has two of those on the machine
  • Anonymous Nov 27, 2008
    leeks at the bottom
  • eleanor_robe Jan 27, 2009
    brandnew kenmore combo is leaking water when water reaches a small load level i heard a some noise on the last load i did looked like drum and agitator separated /3' gap ..what happened ?
  • Ron Coons
    Ron Coons May 11, 2010
    who manufacture
  • 423 Answers
If you own a front loading washing machine and it begins to leak water from underneath, the first thing to learn is where is the water leaking from. On my Frigidare washer (GLTF1240A), there is a lower panel underneath the loading door. There are two philips screws to remove and then the panel can be removed. Use a flashlight as you run a load of clothes. I found the water was coming from the bottom of the round wash tank, where several bolts hold it together.
Posted on Apr 25, 2009
    Champion:
  • 249 Answers
It must umder warranty
Posted on Feb 25, 2008
A LOT of Water ran out from under my washing machine while washing. The tub was still full of water. What could have happened, and where to I begin looking for the problem? My washer is a GE washing machine and I think it is about 4 to 5 years old.
Posted on May 12, 2009
2 Suggested Answers
6ya staff
SOURCE:
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: washing machine leaking at back
You have a bad water pump or the hose that goes to it is split.
About $40.00 in parts.
Posted on Nov 08, 2009
Testimonial: "THANX I WIL TRY THAT found very help ful and quick sheryl "
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
My agitator isn't working properly. Sometimes it works on certain settings
Tighten it up from under neith. its just one screw..if that dont work you may need a belt....
Nov 02, 2012 | Washing Machines
The water won't release when i push the handle
I need to know what the machine model is.
A power wash machine I had a bit to do with used to block up under neith where the water jeted from. I unbloched the small holes with compressed air. This fault occured because I left the machine with shampoo still in the tank. I then tried flushing the system out with clean water before storing the machine. This seemed to work.
Feb 26, 2011 | Vacuums
Our sport duet washer shakes violently even thou it is level
Under neith the tub is a series of shock absorbers like on a car, from time to time these come loose or fail. I have a duet repair manual:HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 24, 2010 | Washing Machines
Washing machine leaking at back
Nov 08, 2009 | Washing Machines
I HAVE THE MAYTAG ATLANTIS TOP LOAD WASHER. WATER IS LEAKING FROM UNDER NEITH ON RIGHT SIDE . WHAT COULD I DO TO FIX IT.
Ibleive pump is located on right rear , thats most likely the leak .remove rear acess to check dont forget the model # when u go a new one. hope this helps haundi24
Oct 26, 2009 | Washing Machines
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My agitator quit working and i took the agitator
theres a belt under neith the unit that is activete whats called wig wags. they activate and that is what activaes itt. v
Jan 11, 2009 | GE Profile WPRE6100G Top Load Washer
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Frigidaire GLTF1240A Front Load Washer Logo
4,118 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
