I have a Hobart Charger for my walk behind forklift I bought it in running condition i connected it to 240 volt the input shows ok but the charger does not turns on ,on the charge outer rbox it says it takes while to start but does not and upon pressing the knob inside the box the machine starts and stops when i take hand off , where could i find pdf or touble shooting guide.pl advice Thanks
SOURCE: hobart lx-g
the problem with the machine restarting is with your keypad, the on button is stuck on and needs to be replaced or you can continue unplugging it. Your other problems are most likely caused by lime build up, is the inside of your machine white. I suggest you buy lime away or similar product and run a delime cycle. When the machine displays 190 is it really 190? Do you see steam?
SOURCE: hobart lx 40 - problem D 1
eo/dr1 indicates no water @sump probe for 3 conc. cyc. sounds like you have a bod drain valve or something caught inside preventing flapper from sealing off drain part,
