42'' samsung plasma. no picture, sound only. took the back apart and it seems the power supply board has some melted fuses (little blue and yellow plastic things). could this be the problem? it seems that if the power supply board is the problem, we wouldn't have sound, but we do.
thanks
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
SOURCE: Philips 42FD9932 42 in. Plasma
look for start up circuit there is dry capacitors giving that problem e-mail me if you need more info
SOURCE: help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
SOURCE: Samsung Plasma SPN4235 No Picture/But Sound
POWER SUPPLY IS WORKING IF YOU HAVE SOUND..WHEN Y-SUS GOES BAD..IF PUTS HEAVY LOAD ON POWER SUPPLY...WHEN YOU TRY TO POWER UP UNIT..IT WILL GO TO IMMEADIATE SHUTDOWN...THIS IS NOT THE CASE HERE..YOU SAID YOU HAVE SOUND...SOUNDS LIKE A BAD Z-SUS BOARD PROBLEM TO ME..CALL ANDREWS ELECTRONICS IN CALIFORNIA FOR PART # AND PRICE..JUST GIVE MODEL #...JOE ACE
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
