RTO Westek Weekly Segment Timer, White Logo
Posted on Feb 10, 2010
I lost the instructions to program a Westek UMDW10 digital wall switch timer and can't seem to figure it out--help.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
731
Points
I have a intermatic t-103 the house wiring is two 25 amp breakers using the white and black as positive bare is gr the timer isn't working. thanks your help is appricated Bob.
Can I feed 12 volt from transformer into Westek in wall timer TMDW40 to run LED strip lighting?
No, the wiring does not allow you to power a 12 volt load directly ... but you could use the timer ... 1) to turn the LED driver on-off ... or 2) to switch a small relay on-off, and use the relay to control 12 volt LED driver
The following page has typical programming and manual for this timer that is sold under several different brand names:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Westek timer manual
Westek TMDW10 is same as Utilitec/ probably made by Intermatic.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Lost instruction for Westek Timer TE02
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
2) Model number and timers change frequently.
If your timer does not show, then add a photo or comment with clear description of timer
Top RTO Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
