Canon IXUS 860 IS Digital Camera Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO RESET SETTINGS OF CAMERA IXUS 860IS - Canon IXUS 860 IS Digital Camera
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Feb 10, 2010
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
951719
Points
10742
1. Press Menu button.
2. Scroll left/right to the 'tools' tab.
3. Scroll down to 'Reset all...'
4. Press the Func/Set button.
5. Scroll left/right to highlight 'OK'.
6. Press the Func/Set button.
This does not reset date/time, language setting, or video system (NTSC/PAL) options.
What buttons should I press to restart camera Canon Ixus?
Hi andresen_3,
In order to reset the camera settings to its default values you need to do the following:
1. Press the MENU button
2. Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
3. Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
4. Press the "Func./Set" button to confirm your choice.
This will reset the camera to its factory default settings
Hope it helps.
Thank You for using Fixya
1helpful
2answers
Download entire user manual for 860is
The IXUS 860 is known in some parts of the world as the SD870. You can download the SD870 manual (and more) from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd870_is#BrochuresAndManuals
My ixus 860is makes a ratchet sound as the lens extends and does not focus on zoom.
lens unit is jammed you need to replace it or you can open up blow up with air and try if work then good
Broken LCD
We are a leading supplier for digital camera replacement including LCD screen. If you are still looking for it, pls don't hesitate to contact us and visit our website http://szaideal.diytrade.com/
28helpful
2answers
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Flash not functionning after lens exchange
Did you replace the lens yourself? If so, no firmware update is going to solve your problem. Besides, there are no firmware updates for your camera.
3helpful
Card is locked of CANON IXUS 960IS
There is a little slide switch on the side of the SD card that will lock it.  It could be that it got bumped the last time it was inserted, or the memory card could be defective.  I saw this happen with a SanDisk card that hadn't been removed from the camera.  Removing the card and sliding the lock switch back and forth, then re-inserting finally solved the problem.  It was a bit disconcerting when it happened.  I would recommend that you get a replacement memory card to use if it starts to happen repeatedly.
Cannon digital IXUS 750
Try your camera settings black and white or sepia take them off.Or just reset all your settings
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
