If your machine is more than a year old expect degradation of the silicone O rings. There are 8 small ones inside the generator. I believe they are metric and silicone. I was unable to obtain metric silicone sizes but found -008 and -010 std sizes locally they aren't exact but worked fine. Cleaned her all up and no leaks at all. BUT be advised that it was over an hour to disassemble and since I knew what I was doing only took about 15 min to reassemble it. I could take it apart again in about 15 minutes easy.
Losen the white junction with te plastic tube. Clean or replace the o-ring.
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
SOURCE: Delonghi magnifica 3200. Water not heating up at
Hi Brian,
I have the same machine a EAM-3200 and the no heating problem is the Steam Generator
Cheers Rob.
SOURCE: Hi, Our Delonghi Magnifica coffee maker seems to
You need to contact Delonghi and order a part. This is the steam/water outlet assembly. This part includes an electronic solenoid which controls the water and steam output. I have had this problem 3 times. You may find the steam/ water is very loose when you try to wobble it sideways. This is the indication as to what is the problem, (as mentioned above).
