Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
SOURCE: epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
