Question about Sony VPL-EX1 Multimedia Projector
Everytime i switch it on it flashes lamp cover even though the cover is not on. Ive switched it off then on again, and the problem still exists
    New Friend:
  • 144 Answers
Try replacing the lamp cover with a new one, if that does'nt work then it could be the sencor for the lamp cover, and if that does'nt work then contact your sony dealer and see what they can do.
Posted on Feb 13, 2010
6ya staff
SOURCE:
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
I was given this model tv. The green and red lights on the front are flashing. Says to replace bulb and close lamp cover correctly. I am missing the lamp cover. Is that going to be a problem?
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
Sep 24, 2011 | Toshiba 62HM95 62" HDTV
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
Hi, i have recently replaced my projector lamp, as it would not power up when switched on the main led on the power button just flashed, after replacing the bulb the light continued too flash, i took all...
It could be the lamp life needs resetting or the filter life needs resetting. Hopefully so, otherwise it could be a faulty lamp module.
Good luck
Aug 02, 2011 | Vivitek D510 Projector
Sony Projector
Ok we're back to the flashing lamp cover LED. The green flashes you are seeing is the TV trying to start up. After it tries for awhile, it will eventually shut down and display an error code, in this case, the lamp cover LED flashing which means either the lamp cover, filter cover or main cabinet sensing switches are not closed, are intermittent or have some kind of wiring issue. A solid lamp cover light (no flashing) would point to the lamp and lamp drive, but the flashing light points to the switches. Give me an email address and I'll send you the training and troubleshooting manual so you can see for yourself. Any ther help needed, please don't hesitate to ask.
Nov 01, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Sep 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Jan 15, 2008 | Sony VPL CS5 Multimedia Projector
Lamp/Cover Error
I had the same problem with a "Sony VPL-ES3" projector. The lamp cover light would flash and the projector wouldn't turn on.
I think its a problem with a filter cover. This fixed the problem for me:
  1. Plug out the projector
  2. Click off the filter at the bottom of the projector.
  3. Plug the projector back in. (the lamp cover light should flash)
  4. Plug the projector out again.
  5. Put the filter cover back on.
  6. Plug the projector in again and it should work fine.
This has worked for me every time I have had this problem.
Sep 29, 2007 | Sony VPL-ES3 Multimedia Projector
No picture
Symptom: LAMP Led Blinking Cause: Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss.
May 13, 2007 | Hitachi 60V500 60" Rear Projection...
Sony VPL-EX1 Multimedia Projector Logo
331 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
