NEC Electra Elite 32D-1 Corded Phone Logo
Anonymous Posted on Feb 09, 2010
Does anyone know how to turn on the caller ID feature?? I have a Elite DTU-8D-2 system in our office. Does this have to be turn on, on each individual phone?
  • Anonymous Feb 09, 2010
    Our contractor has closed shop and our phone company says we have the feature on our lines.
tfelton3
Level 2:
New Friend:
  • Expert 183 Answers
  • Posted on Feb 09, 2010
tfelton3
Expert
Level 2:
New Friend:
Answers
183
Questions
Helped
63947
Points
490
You need to subscribe to Caller Id from the phone company! If you already have it, it should work, otherwise I would check with your NEC contractor.
  • tfelton3 Feb 09, 2010
    what area are you in? AT&T does NEC, also there are numerous websites like tek-tips.com.... Good luck. I work on Nortels and we do nothing to turn on caller id!
NEC Dterm 80 phones
Caller id would have to be truned on, in system programming, as long as the caller id card is installed. If it works for the corded phones and not the cordless phones than, the analog caller id feature needs to be programmed. check out ldtsnj.com
1helpful
I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Caller ID Scroll
Your system needs to have a mif-m card and kmm chip installed and all programming setup in order to scroll through the caller id. If this is all setup you can hit the directory button and than use the arrow buttons under the display to scroll. ldtsnj.com
Need to know how to change features on a DTU-16D-1 office phone
You need to find the external source to change the music. It can be a radio, music service, recored information etc. Look for the Electra Elite Attendants manual to change the time and date. If you prees "feature" 9# enter the time , press recall to cahnge the am/pm. press hold to change calendar settings or feature to exit. When changing calendar settings, press recall to select day of the week dial # to move cursor to day of month field. Enter day of month. press recall to select month. Dial # to move cursor to year field. Enter last 2 digits of year. press feature to exit. Use this link for manuals. http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
Caller id recall
You need a mif-m card and kmm chip installed in your system in order for this feature to work. ldtsnj.com
Change extension ID
extension id is changed in system programming
Caller ID Display
This one could have different variables.
  1. your CO lines must have CID
  2. your CO card in the system must have CID capability
  3. older systems have a limited number of extensions that can display CID (16)
  4. your ext must be set to ring.
1helpful
2answers
NEC DTU-8D-1A TELEPHONE
Press Feature 1 That will turn the mic off, or on.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
