PDF
For Great Northern Popcorn Company Models: 6000 Roosevelt Full ... 4OZ POPPER ASSEMBLY. Model No.: UE40010. Voltage: AC 120V-60Hz. Input Power: ...
Any Gold Medal dealer will be able to find one. There are 3 different styles depending on the age of the popper.
It is always cheaper to repair Gold Medal kettles, replacements are very expensive. That model they run $750-$1100.
Contact Gold Medal to find your local dealer for service. 1-800-543-0862
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
There are no replacement parts for Nostalgia Electrics equipment.
Double check that the kettle is plugged in, that the switch has power. If inclined open kettle and inspect wire connections and continuity, beyond that the popper is not fixable.
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
Have a look here http://www.amazon.com/Nostalgia-Electrics-CCP509-Full-Size-Popper/dp/B0000CFW9M
Perhaps your problem like this?
When the kettle is popping popcorn, the metal rod with gear on the end pops out of place. Therefore, the kettle stops spinning and the popcorn burns.
>The allen screw that holds it in place need to be tighten.
