Tissot PRS 200 Wrist Watch Logo
Posted on Feb 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I use my watch???
I have recently recieved a used watch as a gift, that I had previously admired...It it a Tissot PRC 200...I know how to set the time and date, but there are two othe buttons and two dails that I have no idea what they are for or how to use them...Can you please help me solve this mystery
  • 1 more comment
  • Anonymous Apr 07, 2008
    user manual needed
  • naeemch May 13, 2008
    I have Tissot PRS 200 but don't know how to use two dails else than time n date crown.
  • Anonymous Jun 22, 2008
    tachymetr
HyeProfile
Level 2:
  • Expert 35 Answers
  • Posted on Aug 05, 2009
HyeProfile
Expert
Level 2:
Answers
35
Questions
0
Helped
40922
Points
100
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Won`t start after battery change
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs....
I bought a Tissot prc 200 quartz chronograph a month ago and it suddenly stopped working. Can someone please tell me what's the problem?
Well, I go to a jewelry shop called fast fix and purchased a "forever battery " most obvious answer is that the battery is simply dead. Second, there may be debris in the clockwork, which will also kill the battery. Good thing about the forever battery method is that they will clean out the watch for free usually, which saves on them replacing the battery.
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
1helpful
Prc 200 needing battery replaced every week!!! i
Your watch is draining the charge on the battery. It is possible that you have a bad coil or circuit block that is causing the battery to die. An acceptable battery should last you at least 9 months to a year. You need to send your watch in to the manufacturer to have them fix the motor.
1helpful
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
3helpful
Hi, I've got a broken spring bar on my Tissot PRC 200 and would like to replace it. I understand that it has got a lug width of 19mm. Does that mean I should buy a 19mm spring bar, or should it be a...
Two of the spring-bars broke on the clasp of my PRS200, so I took it to an un-named watch repair shop that was closer than the Tissot-authorized store (Leslie Gold Watch Co.) at which I bought the item 5 years prior. After the repair, the clasp kept popping off, so I took it to the Tissot store, and they told me that it was because the ends of the bars didn't fit properly. They replaced the faulty bars for me at no cost, and the watch has been sitting on my wrist fine for the last year-and-a-half.
2answers
My prc 200 is not working maybe its the battery?
These watches are "automatic" which means that the are self winding.
They will run for 1 -2 days before stopping. Shake the watchgently from side to side for a few minutes and it should start again.
(These watches need to be constantly used to keep them working).
2helpful
How do I set date on my Tissot PRC 100?
alright pull the crown (thats the knobby thing) to position 2. Then turn clockwise until correct date. Now you should have the correct date.
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
