SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
LINK to part info
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
SOURCE: hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
SOURCE: paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
SOURCE: HP LaserJet 2430n is not grabbing the paper like it used to
You need to replace either the pickup roller or the separation pad (or, optimally, both at the same time) - both should be removable without tools, they just snap in. You can order new parts at http://partsurfer.hp.com - shouldn't be more than $20 worth of parts. You can help reduce the problem slightly by roughing up the rubber on the pickup roller and the cork on the separation pad by scuffing both with a light grade of sandpaper, just to give it some tooth. But replacing them is best, it'll fix it!
