Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow Logo
Posted on Feb 08, 2010
Bosch & Lob elite ed foggy
Bosch & Lob elite foggy. There appears to be something on the inside of the lens.
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
6077
Points
42
Bushnell own bausch&lomb scopes and I have had good luck with there customer service. I would call them first .Just make sure you send a detailed letter with scope.Good luck
Samsung SC-D353 foggy lens - what can I do?
If the lens on your Samsung SC-D353 camcorder is foggy, there are a few steps you can try to clear it:
  1. Clean the lens using a lens cleaning solution and a soft, lint-free cloth. Be sure to gently wipe the lens in a circular motion, taking care not to scratch it.
  2. If the foggy appearance persists, there may be moisture inside the camcorder. You can try using a hair dryer or a can of compressed air to blow out any moisture that may be trapped inside the camcorder.
  3. If the foggy appearance is still present after trying these steps, there may be an issue with the lens itself. In this case, you may need to have the camcorder serviced by a professional.
I hope this helps! If you have any further questions or if you are having trouble clearing the foggy lens on your camcorder, don't hesitate to ask.
1helpful
My iris blades are loose inside the lense.
This happens when lens get any sudden impact or dropped on hardhard surface. It requuires skill &practice to fix it.best is take to a technician.
3answers
How to clean the lens on the headlight on a 2002 chevrolet
the lens is the outside piece that the wind hits when driving. you don't have to remove anything to get to them. what exactly do you mean by lens.
Lens shacking automatically
I have a D200 with a Nikkor AF-S DX 18-200mm ED zoom, and I have a similar issue with the inside of the lens shaking when I turn it on, It turned out to be a problem with the vibration reduction motor inside the lens. I first noticed a problem when zooming that it wasn't smooth, as though the inside lens was catching on something. It turned out that a roller inside the zoom somehow caught the wiring strip inside the lens and damaged it, causing the VR motor to short out.
There are forums that tell you how to repair the problem yourself on that lens, providing that you can get the replacement parts. I elected to send mine in for a repair, and hopefully its going to cost less than $AU200.00
Foggy projector lens
possibly panels not len assembly is picture colours ok but foggy if so remove lens assembly and view it itself if foggy could be faulty lens or a lens sometimes plastic lens's did this
john www.jvsvisual.com
6helpful
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 • Cameras
1helpful
My daughter's digital camera is foggy on the inside of the lens. Any chance this will resolve itself? No idea what happened to it. I've wiped the lens clean on the outside but see it's still foggy on the...
HI there put it in sunlight for few hours & watch it every 10 minutes ok. After that if its not clear then visit the service center. They will clean it . May be free of coast or max 10 USD they charged. Its happened when you use in in a cold and hot place continues. For example you was sit in a AC room and came out a sunny hot out side that time that moisture will comes. Hope you understand . Thanks.
My sony cybershot DSC-H10 camera has a foggy screen
is screen is foggy/image formation is foggy,chaque the lens unit
Yesterday i bought a secondhand Nikon AF-D 14mm f2.8 ED for a very good price here in the Netherlands. The seller didn't have the box, manual, and yellow waranty slip. The integrated Hood has a dent so i...
better you buy new one because the circuit inside lens get thinner and after some month or year it may gives you problem. if u are buying same then use for your
studio purpose
Water damege
That depens if the fog is inside or outside, outside it usually dries faster than inside. You are advised to let it dry at least another 24 hours , if the lens is still foggy after that , thab you must go to a repair shop to let it be cleaned.
Top Bausch and Lomb Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
