Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit Logo
Posted on Feb 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting preset stations
I need help in resetting preset stations?
My name is Gil
Anonymous
Level 2:
  • Expert 97 Answers
  • Posted on Mar 29, 2008
Anonymous
Expert
Level 2:
Answers
97
Questions
0
Helped
45131
Points
219
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
1helpful
How to I delete an occupied preset and enter another channel
My experience has always been to replace the current station preset with the new.
I recall two process:
  1. The first locate the new station that you want and tune the radio to the station. Press and hold the specific preset for several seconds to replace the old station with the new.
  2. Tune the radio to the new station and press the set button if so equipped and than press the preset button. In some radios they have group 1 and group 2. In that case press the set button once for set 1 and press it twice for set 2 and then press the preset button.
Hope this has helped?
2helpful
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
1helpful
I want to reset the preset stations
To reset or set the preset station you want you need to do this 1 press tuner/band to select the band 2 Press the << down or >> up to tune to desired station 3 Press the  set to stor the station the preset number begining with one appears display you cannot stor a total of 32 preset stations if you need more information check out the manual here .. Manual
2helpful
4answers
Advice on how to set tuner presets on AlpineCDM 7838R in car stereo CD . Unit has both permanent and switched power supplies, will search stations and hold them when switched off but cannot work out how to...
some of the alpines had an odd way of setting the presets manually. you need to press any of the 1 thru 6 buttons for a few seconds. when the display starts blinking just pick which preset button (1 thru 6) you want to set the station at and press it once.
2answers
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
2helpful
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
2answers
JVC RX 809V home reciever
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Setting up fav stations
seek to the station you want and hold down the preset button you want that specific station set to.
for ex: seek to 101.3fm and hold down the number 1 preset button for about 5 sec.
Top Sirius Satellite Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
