Hi, I'm using Windows 7 Ultimate & MS Office Outlook 2007.
Outlook was running error free for quite an year. Three days ago I sync'd my mobile data with Outlook & backed up on it. I used to do it quite often
but since last time my Outlook has started crashing everytime I open it even when the mobile is not connected. As soon as I open Outlook, it closes
with an error message "Microsoft Office Outlook has stopped working. A problem caused the program to stop working correctly. Windows will close the
program and notify you if a solution is available."
No other application is giving any problem.
I have tried:
Microsoft Office Diagnostics (Setup Diagnostic, Disk Diagnostic, Memory Diagnostic, Update Diagnostic, Compatibility Diagnostic)
Scan and repair corrupted Outlook data files through scanpst.exe
Deleted all Calendar, Contacts & ToDo items that were sync'd.
The Recovery Manager is also showing only two reset points but not showing that date or prior to problem version to rollback.
Pls help!!
Regards
Hey,
I was having the same problem with Outlook 2007 on my Laptop, looked for all the possible resolutions but no Clue..
Then I tried to check the addins I was using in Outlook 2007, I found that after disabling the unnecessary addins from Regsitry I am able to use outlook 2007 without any issues.
For Disabling the outlook addisn you have to go to:
Start> Run> Type Regedit> Hit Entre> HKEY_LOCAL_MACHINE>SOFTWARE>MICROSOFT>OFFICE> OUTLOOK>ADDINS there you will find all the Addins, Please right click on the onw which is not required to go to modify & change the value to 0.
It will disable the Addins from Registry. we can enable the Addin when ever required.
Close & re launch your Outlook.
Hope this will help you in resolving the issue related to the outlook crashing.
Cheers!!!!
Vivek
