SOURCE: Problem with Hotpoint WD64 Washer Dryer
Effectively it looks like a water heating problem.
When the water cannot be heated sufficiently, the machine waits until water reaches desired temperature.
So that the program takes longer to complete.
Heating problems can be caused by:
Faulty heating element
Faulty heating element solenoid.
Faulty thermic switch (in this case the water will get hotter than normal)
The heating element and the solenoid can be tested for continuity using a multimeter.
If the machine is slow to fill check also that the inlet valve is fine and not obstructed.
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
SOURCE: Hotpoint WT761 washing machine - Error code F-10
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
SOURCE: My Hotpoint Ultima WMD 960 displays
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
SOURCE: wmd 940 wont fill,, water pressure ok,hose ok,f01
Solanoid. does it fill on any other programe. try hot wash, then rinse
