No, if the computer will start and it run bios screen and boots into windows
the cpu is fine, you need to get a better cpu cooler.
Buy a better cpu cooler for your socket, coolers are designed for the Socket that the processor plugs into.
Go to Newegg.com and llok for a cooler, you will see reviews by people
and if they liked the cooler, there are little eggs next to the product
is it has high ratings, you will see what I mean when you look at the site.
The page I posted is already on the cooler page, just llok to the left side
and look at sockets and pick your socket out to look at coolers for your system.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Try to clean the heat sink from dust (a vacuum cleaner with a tube and nozzle is handy for this). If you have to remove the heat sink, remember to clean both the CPU and heat sink *very* thoroughly from any thermal grease or heat conductor pad residue before you reapply new grease / pad for reassembly.
If you have no idea what I am talking about, study the article at http://www.hardwaresecrets.com/article/274 or find a local techie to do it for you.
Improperly assembled heat sinks, or malfunctioning fans can fry a CPU at an amazing speed (seconds!). However, since your PC does have a alarm function that shuts down the CPU, you may be lucky.
If the CPU got that hot it may have cooked
You could try taking the CPU off and re-bonding it with Heat Sink Compound also fit some extra cooling into the side panel
