Uninstall the previously installed drivers from add or remove programs in control panel.
Check the part # or model # on the box or on the device. It will start with "F5D or F6D...."
Go online and go to "www.belkin.com/support"
On this support site, on the tp right corner, you 'll have "search by keyword" in a blue small rectangle box.
Type the model or part # here in this search box and search
You ll get a page with search results and mostly the 1st search result would be Drivers. Click on that link.
Now, you may see lot of versions for the same model #
Check for ver # or v# or version # on the box on or near the bar code.
After getting the version number, check for the OS compatibility. See if your Windows is there in the list corresponding to your version. If yes, download, else get the product replaced.
If you download, transfer the downloaded file on the computer which needs the drivers using a flash drive or so.
Unplug the adapter, and run the downloaded file. This would surely work.
Else revert to me for further clarifications.
