With charger plugged in and hooked up to battery no lights turn on and any button you push no lights or functions work
Open the case by unscrewing the 4 case screws. hold the case about 1" above carpet and shake downward ( very tight ). There are 2 connectors from the circuit board on outer case to the circuit board mounted to base ( 2 prong and 5 prong ). The 5 prong connector was disconnected on my charger. Put the connector back on and problem fixed! no fuse visible to me.
Check the fuse.
Where is the fuse that Chis Bell mentioned?
