Casio G-Shock G600-1AV Wrist Watch Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace battery on g-shock - Casio G-Shock G600-1AV Wrist Watch
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Feb 07, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291851
Points
7081
It is advisable to take your watch shop and ask them to replace the battery for you.
One of the cries for help that appear on this web site is "I have changed the battery and the watch doesn't work now".
It is not really worth the risk of doing it yourself.
G-shock GA 2100 - New batteries drain in couple of hours
The battery compartment may not be making proper contact with the batteries. This can cause the batteries to drain quickly or not work at all. Make sure the batteries are properly seated in the compartment and that the terminals are making good contact with the batteries.
The watch may have a faulty component that is draining the batteries. This could include the display, processor, or other electronics in the watch. If the watch is under warranty, you can try contacting G-shock customer service for assistance.
The watch may have been damaged during the repair process. If the watch was mishandled or damaged during the repair, it could have caused a problem with the battery compartment or other components of the watch.
To troubleshoot the problem, you can try the following steps:
Check the battery compartment: Make sure the batteries are properly seated and making good contact with the terminals. Clean the terminals and the inside of the compartment with a soft cloth if necessary.
Check for faulty components: If the watch is under warranty, you can try contacting G-shock customer service for assistance. They may be able to help you diagnose and repair any faulty components.
Check for damage: Inspect the watch for any visible damage that may have occurred during the repair process. If you find any damage, you may need to take the watch to a different repair shop for further evaluation and repair.
2answers
How do i replacs the batterie in a g-shock illuminator
<P>Thanks for contacting FixYa.</P><P>Found a great tutorial for you.</P><P>Ive been changing batteries for 25 years and I wouldnt touch this one, so best of luck to you!!</P><P><A href="http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html">http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html</A></P><P>If you do this one, then you should get in the biz for sure!!</P><P>Jewel</P>
Casio g-shock protection model blank face after new battery installed by a jeweler
What kind of battery did they put in it?? G shocks are powered by a rechargeable solar battery!!! Should not have been replaced unless it was the same type of battery. I would be going back to jeweler and asking them to send your watch to Casio and they pay for the new solar battery. Let me know what happens.
1helpful
2answers
Replaced battery in Casio G Shock 2317 and now hands do not move at all.
Take the battery out again, wait for a few minutes, then replace it and shortcut AC and battery. After that you have to reset your watch completely. To find AC you will need an eyeglass.
1helpful
What watch battery do i need?
If you are asking for that, it means you want to replace battery yourself, and if you do, you will have to open your watch anyway. So, open it, take the battery out and memorise all the writings on the battery. This is the type of battery you need.
Do not forget to rate, please.
If I was wrong with my guess, then submit all the writings on your watch caseback and dial, please....and do not rate yet.
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
2answers
Casio g-shock 2900
Hi there
There is no contrast adjustment...
Batteries low can affect the contrast. Try replacing the batt first. Is it all black? If so, the LCD is damaged.
2helpful
2answers
You didn't have GW510A (limited edition) Assume this is similar?
It's a common problem, now that the earlier Tough Solar watches are getting on in years. Plus, there was apparently a bad production run by the battery manufacturer (Matsushita/Panasonic), so there's a certain subpopulation of G-Shocks that are seeing premature failure.
Replacement is easy. You'll need a jeweler's screwdriver set, ideally some plastic tweezers (though a toothpick will do), some metal tweezers for one of the final steps (but not for handling the battery), and if you're smart some latex gloves to keep everything pristine. Get a little tube of silicone grease, too (and ONLY silicone). Careful with it, though-- it's impossible to wash off of clothing, etc.
It's all proceed-at-your-own-risk, of course, but good instructions are posted at http://forums.watchuseek.com/showthread.php?t=41076
Mind the little springs, and note which one came from where.
Altogether, it's an easy job. Good luck!
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
