Zune program deleting songs from device without permission
I plugged my zune onto the pc. Next thing I knew, I was a few songs
less on the device. I had not add or delete any songs from my collection in a while but each
time I connected to the PC, it was a hit a miss situation. I just sync
it again and now it removed additional 300 songs from my device. My
device is now has less than half the songs since I plugged it in without any intervention. Has anyone already addressed
this issue or it is just me who don't know how to work the software.
Any suggestions?
I'm having the same problem. This happened to me 3 times!!!! I chose to sync my own music. The software is flawed.I'm having the same problem. This happened to me 3 times!!!! I chose to sync my own music. The software is flawed.
I also am having this problem! It has deleted over 300+ songs! =[
AnonymousMay 14, 2009
I have noticed that songs that some songs that i play often have been deleted from my zune. I have also noticed that lately MY music: the cds i own that i synced into the zune have started to display the dreaded "Rights have expiered" Notice on them. I hate that ****. I thought that zune was cool. ZUNE U HAVE LET ME DOWN!I have noticed that songs that some songs that i play often have been deleted from my zune. I have also noticed that lately MY music: the cds i own that i synced into the zune have started to display the dreaded "Rights have expiered" Notice on them. I hate that ****. I thought that zune was cool. ZUNE U HAVE LET ME DOWN!
You can't post conmments that contain an email address.
I'm assuming you have the Zune software installed. You'll need the software in order to interact with the Zune device, it does not work as a "mass-storage device" like some other media players.
The Zune software will find all your music. Open the software and on the top left make sure you're in the "Collection" and then "Music" category. Then click on the right hand side on the "Songs" tab. You'll see all your songs on your computer. Connect the Zune and wait a few seconds and in the bottom left hand corner of the software you'll see your device connected.
Click on one of the songs and then press "CTRL + A" and all of your songs will be selected. Click and hold and then drag one of the songs to the little icon of your Zune in the bottom left and then all of your music will sync to the device.
Hope this helps.
you plug it in the computer,go to the zune program,go to "device"and go to whatever you wanna delete and right click and go to "never sinc with with....."and its gone
To reset the zune you must press and hold the back button and the top part of the zune pad. Other parts of the zune pad will not work.
When plugging the zune into your PC does the PC detect it (device manager -> portable devices). You should hear the ding sound of hardware connecting.
If it is connecting to the PC and is not detected by the software than it is likely a permissions problem. Right click the software icon and choose run as administrator.
If it is not detected by the PC than check your usb cable and make sure your zune is charged and not frozen.
Just don't use the software. Click Start > My Computer > find your Zune (will be represented as an additional drive there) > open it and delete, drag and drop songs, video, pictures, etc.... When your done right click on the USB device connected icon in your systray (next to your system clock) and select eject USB device, locate your Zune in the dialog box that appears and when it says it's safe to disconnect, disconnect it.
yes it is due to the zune software not being able to locate the songs. make sure they are available and keep trying. also the zune software constantly search the internet to update your music information and album art. it will automatically update the songs on the zune when you connect it
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
I had a 30g w/same problem. I installed the Zune software from CD. Plugged the Zune into my USB jack and waited hrs for the full screen battery icon to go away. It never did. Here is what I did to fix it. I left the Zune disconnected until its battery drained and the lcd went dark. In this state, pressing the play/pause button, caused the full screen battery icon to appear briefly before the lcd went dark again. With the Zune disconnected from my xp pc, I ran Windows Update in express mode. I have Windows system restore and auto-update turned off and rarely update my pc, so I also took the opportunity to take a manual system check-point (so I could restore from the check-point if an update trashed my pc). I took and installed all the latest Windows updates. When it was done, I had all the latest security updates and IE 7. At this point I went to http://www.zune.net/en-us/products/zunesoftware/download.htm and downloaded the latest Zune software. I installed the Zune software update. I ran the new Zune software on my PC and found the device tab. NOW I connected the Zune to a USB port on the back of my PC. The full screen battery icon appeared on the Zune but nothing appeared in the Zune software. I left it this way for a few minutes. It occurred to me that I might get more power through the USB port if I turned off my other external USB devices, which I did. Within a few minutes, the Zune FINALLY came to life and a Zune splash screen appeared on the device. The device booted and was FINALLY recognized by the Zune software on my PC. Shortly after that I noticed that it already started synchronizing with my PC music collection. I figured it would charge up and download my entire collection (20gig) so I grabbed some sleep for a few hours. When I returned, the PC was asleep too. Unfortunately, the Zune was not charged and had stopped sync'ing. Not to be discouraged, I woke up the PC, exited the Zune software and left the device charging for an hour or so. When I returned, the device was about 80% charged. I quickly disconnected and played my first music video on the device!!!! I reconnected (the Zune software auto-launched) and left it sync'ing and charging for a while longer. When it was 100% charged, I disconnected and have been using it for a few hours. It was a long painfull road to get this thing setup, but it was WELL WORTH IT! I am already a huge fan of this device. In fact, I'm considering passing this one on to my wife so I can get the 80gig. Hang in there, it's worth it!!!!
PS: one sidebar -- I have noticed that the pc software will only sync about 800 songs in a session. I have simply been restarting the sync to get the next session going. At this point, I am fully synchronized and have 4.5 gig free.
