First make sure that you are getting suction from the bottom of the
machine. Most of the time the squeegee is worn out which does not allow
it to pick up the water like it use to. Turn over the machine and
inspect
the squeegee. If it looks worn or bent then it may be time to replace
it. You may also consider replacing the filter. These are the two most
common parts that wear out.
here is a link the parts for your a
h3000 floormate
H3000 Parts
http://www.usavacuum.com/category-s/85.htm
NORMALLY SUCTION PROBLEMS ARE CAUSED BY A POOR SEALING PROBLEM OR AIR LEEK. CHECK ALL BLACK RUBBER SEALS TO BE SURE THEY ARE SEATED CORRECTLY, NOT WORN OUT OR TORN. BE SURE FILTER AND TOP TO FILTER ARE IN PLACE, AND YOU MIGHT WANT TO LUBRICATE SEALS AND CONNECTION WITH A LITTLE VASILINE OR CRISCO IF YOU ARE A MOM LIKE ME. MINE IS WORKING FINE NOW, HOPE THIS HELPS.
SOURCE: Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
SOURCE: Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
