The blade is able to be set to different angles by the handle under the front edge of the table. There is a lock handle to keep the angle set correctly. Loosen the lock handle, press a square (90 degree tool) against the flat of the blade - not the teeth - then lock the blade in place.
Put the model number (it'll be something like "123.3321") in the Google search bar and you'll find a manual for download. Then list on Craigslist and you'll be rid of it quickly!
I can't find that exact model number BUT if you leave off the 21 you can go to "managemyhome.com and under manuals click and it will redirect you to type in the model number but stop at the 8. The manual is 40 pages long. It should help you with your questions.
Craftman is a Sears product and they have a parts department you can access online or you may have a service department in your area. Following is a link for the online department. I hope this helps you, please rate if this answer has helped you in any way. Good Luck and have a great weekend.
