Canon EOS 30D Body Only Digital Camera Logo
Posted on Feb 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cf error - camera now dead
Please can someone help me. I did a shoot with my 30D this morning - tried to download images via card reader, and computer couldn't pick it up - said the card hadn't been formatted. I put the card back into the camera to check if images were still there, and it came up with a cf error. I turned it off and took the battery out - replaced the battery, and now the camera wont even turn on. (the battery is charged) It has done exactly the same thing with my 400D, but with a different card. I am a wedding photographer, so these cameras are very important to me!
Anonymous
Level 3:
  • Master 667 Answers
  • Posted on Feb 06, 2010
Anonymous
Master
Level 3:
Answers
667
Questions
0
Helped
221683
Points
1593
None of this sounds good. I would start by checking the condition of the pins in the CF card slot. A small light and a loupe will help. If any of the pins are damaged, bent, or even missing, then the camera may have had a short circuit and blown the internal fuses. Neither the pins or the fuses are user replaceable.
2answers
What happens when I get Error code 20 on a canon rebel eos rebel t3i 600d?
From the Canon owner's manual:
"Error codes 10, 20, 30, 40, 50, 60, 70 and 80: Shooting is not possible due to an error. Turn the camera off and on again or re-install the battery. Operate the power switch, remove and install the battery pack again, or use a Canon lens (p.32, 28)."
tip
How to recover photos from CF Card?
CF card is widely used by digital camerafor its larger , from about 512MB to 64GB, lower cost as well as fasterspeed, which allows digital camera shoot under special conditions, such asmoving objects. The most popular and trusted brands for CF Cards includingKingston, Ritek Ridata, SanDisk, Transcend, Apacer, Viking, and Lexar.
Reasonsof lost photos
Lost photos in CF cards can be caused bymany reasons: card damage, failure, corrupt, etc. and the following are some typicalphenomena.
1.
Accidently selected "Format" onyour digital camera and erased all the pictures on the CF card.
2.
Keeping take photographs whenthe camera battery is at the end of its life.
3.
When upload images to computer,mistakenly judge the finish of uploading and eject the CF card ahead of time.
4.
Turning off the camera beforethe image is completely written to the CF Card
5.
Receiving an error message like"card not formatted", "card not found" or "no images found"......
How to recover lost photos from CF card?
Before recovery, you should know that yourphotos are not erased actually. It stored on CF card as a file. When you formatthe card or deleted photos from the card, the data on which the images werestored is not deleted. It only allows new pictures to take its place.Therefore, make sure not taking new photographs any more in case that theprevious photos would be overwritten.
Data Recovery program like Card DataRecovery can help you get backpictures from CF Card easily. Download Card Data Recovery and Install it onyour PC. Take out the CF card from digital camera and connect it to your laptopor connect digital camera to PC directly. (If your desktop or laptop has abuilt-in card reader, things will be much easier, if not, you need a cardreader to help you.) Then your CF card appears as a drive letter when you go to"My computer" If you see this, it means Card Data Recovery can access andrecover your pictures. Select "photo" and scan your CF card. The process isquick and all recoverable images will be listed with the same signature. Previewthe photos before recovery and restore what you wanted.
Besides retrieve photos, Card Data Recoveryalso can recover video, music, files, etc. Popular video and audio formats likeMOV, FLV, AVI, WAV, MP3, MP4, MPEG, etc. are available with it.
on Apr 21, 2011 • Computers & Internet
My card has pictures on it, but when I press playback button & turn dial it does not show an image.
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
An error 2
Error 2 relates to the CF card for sure. Try if you can to format the card elsewhere such as another camera, or on a PC via a USB card reader.
If you still have issues with the card, it is dead - get yourself another one - or preferably two!
Canon eos30d
Bent/broken card reader pins. Take a flash light and look inside the card reader. There you'll see two rows of pins, 1or 2 will be bent (common problem).
Needs repair service.
Error code 22
ERR 22: CF DRIVER
DESCRIPTION: This error occurs when image data cannot be written to the CF card. This error can occur when the CF card is not fully seated in the camera or if the D30 does not detect a card-ready signal within a specified time limit or when the CF card is not usable because it has been corrupted or physically damaged. It can also occur when the camera's battery level is insufficient to completely write the file to the CF card. REMEDIAL MEASURE: Use the DC Coupler or recharge the battery first. If the error continues to occur with sufficient power available to the camera, check that the CF card is properly inserted. If that's not the problem, then try replacing the CF card. If that does not solve the problem, have the EOS D30 and one of the CF cards that is causing the problem examined by a qualified service technician.
Got this from here: Digital Outback Photo
3answers
Canon 20d raw to pc
Have you ever been able to view the pictures on your pc?
Have you got a card reader that can view the card contents externaly from the camera?
I found the Canon software is quite as happy from a card reader as it is reading from the camera. (I have the next model up, 30D.)
Have you tried upgrading your software, or tried using a third party image program to read the raw files?
Over to you!
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
3answers
Scandisk curropt
You'll need a CF reader/adaptor for your computer, and software such as this
http://www.softwarepatch.com/software/smartrecovery.html
Just type "recover CF card data" and you'll find a host of downloads.
2answers
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
