http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips
remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (
TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes
direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
lost the book with the program codes and was just looking for the code list online but can't find it anywhere ...why is this not simple?...it's just a code list...why wouldn't intec just make it available to see online...hello.
I changed the batteries in the remote and can't find the manuel to tell me how to reprogram the remote to my tv.
i need to use a INTCE remot control for RCA tv
