The only way is loosening the screw or nut and making it back manually, but it is the right way to fix it, you should review the KEYPAD, specifically the down key. tries to do the following: turn it off and rub the area where the key now is turn it on again if it does not work with you to replace that part
I have this same problem with my Proform 730CS. What screw would I loosen to try to get the incline to drop back down to the lower position? I want to try this and then try the recalibration again, since I cannot figure out how to get the incline to lower from near the top position. Thanks
Were you ever able to drop the incline on your Proform 730CS? I have the same model, haven't used in years, is in great shape almost like new. Some years back this just happened where the incline is at the top position and I never tried to repair it. Is there a way to just manually lower it? I don't care to ever incline it, just want to walk, but I don't know what screws to remove and how to do so. Thanks for your help! [email protected]
