SOURCE: The key pad doesnt work, had it less than a year.
The panel may have a short or need to be tested for replacement. You should try and leave unplugged for 8 hours so power supply can fully drain power and reset microwave
SOURCE: i have a ge over
hi,go check first the ribbon connector of the key pad they might get corroded and loose contact.clean and re tighten the connector ...clean also the contacts of the switches carbon particles occurs in the contact switches..use a contact cleaner to clean them..
