Compaq Presario M2000 Notebook Logo
Posted on Feb 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i turn off the scroll function on the mouse pad ? (compaq presario m2000)
Anonymous
Level 3:
  • Master 2,517 Answers
  • Posted on Feb 05, 2010
Anonymous
Master
Level 3:
Answers
2517
Questions
Helped
484000
Points
8373
Dear friend don't worry its so easy thing. You have functional in in your keyboard. Its called "Fn"
Press FN+F12 Key for turn off/on scroll function .
Thanks & waiting for your reply.
Anonymous
Level 3:
  • Master 644 Answers
Anonymous
Master
Level 3:
Answers
644
Questions
Helped
217673
Points
1886
Goto the control panel, click on the mouse icon, then the advanced tab in mouse properties, click advanced settings, goto touch pad and uncheck the little box next to use scroll fuction.
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
Where i find wireless setting in presario m2000
Download and install the wireless driver for compaq presario m2000
see link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp
Go to Driver - Network category .
Next follow the troubleshooting steps at the link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document
Just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
1helpful
Repair manual for compaq presario M2000
Free Service Manual,
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
Plus;
http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
For additional questions post in a Comment.
Regards,
joecoolvette
Hi, I have a Compaq Presario CQ56 & the scroll area on my mouse pad isn't working. Can this area be turned off and if so, is there a way to turn it back on/unlock it?
The scroll pad on the touch pad needs a particular driver Synaptics Pointing Device Driver. This will actually run at the startup after installed which will activate the functionality of scroll on the touch pad. You can also actually turn this function on and off so this is a friendly user.
If you do not have that driver that comes with your laptop you can go here:
http://www.compaq.com/cpq-country/cpq_support.html
or here
http://www.synaptics.com/support/drivers
Good day.
Mouse pad buttons don't work properly. Scroll works fine.
Update your drivers, first:
http://www.fixya.com/support/t1381478-webcam_not_working
Then go to Start: Control Panels: Mouse and double-check your configuration for each button.
5helpful
2answers
Scroll sections on mousepad not working
almost certainly this means that the drivers for the touchpad have reverted to the windows generic drivers. Try the driver from Compaq here. Sadly, without knowing the OS and exact model number of the laptop I can't be more specific on the link than that. The exact model of the laptop is usually printed on a sticker on the bottom.
check the sound card drive
see if u have installed the same driver required by the laptop
TOUCHPAD
go to mouse setting under control panel.
You will find a place to turn it off.
4helpful
2answers
Turn off scroll button
hold down the fn key and press the scroll button.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
