A message comes up when i try to open itunes store and it says We could not complete your itunes store request.An unknown error occurred (306)bigjohn
Some people have been doing this
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
do a google search for "itunes error 306" for other discussion boards on the topic, seems to have occured after an itunes update conflicting with OS (go figure right?)...hope this helps =)
you sir, are a genius of epic proportions. had the same problem, this worked for me. cheers.
Hey Jenn77124,
Thanks a lot dude - i was psssd off with Apple's inappropriate error message "could not complete your request". But the above recommendation worked really fine.
Cheers,
RRPV
Tried for 2 weeks to get a response from Apple - useless!!! all sorted Ta
GeeTee
worked for me here in Oz too. Thanks Jenn77124-you are the Wiz! Are there side effects in not using a proxy server for your Lan?
Worked here in Oz too - thanks Jenn77124. You are the Wiz! Any side effects from not using a proxy server for your LAN?
thanksssssss it worked for me tooo.....thank you so much@@@
A massive, MASSIVE THANK YOU, Jenn77124. I would love to know where you get this level of knowledge from. I have an IT degree, and I didn't know! WELL DONE, TIMES A MILLION!
Thank you! Thank you! thank you! a million times thank you!
Thxxxx lot its done
faizal-uae
