Sounds like you have Verizon software on your computer. The router has nothing to do with that. Go into control panel > add remove programs and remove the Verizon software.
unfortunately, no. You would be better off Ebaying the actiontec and getting a dedicated router- the reason is that the only uplink on the actiontec is the dsl port- not ethernet. Theoretically you could mod the firmware to make the wireless an access point only- but it would still have the achilles heel of needing an uplink.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
It depends on your DSL connection- technically anything above 56k is "high-speed internet"- if you are concerned about the speeds you are getting, contact Verizon tech support for further assistance- you could have an issue with your connection, and they would be the ones able to setup for a technician to come out/ have the maintenance office repair the connection
You will have to contact Frontier and give them the Mac address of the equipment and they will tell you if it will work or not ( and they will also need to put it in their system)
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
If my memory serves me, I didn't install the software for my Actiontec modem/router combo. I call Verizon and told them I refused to install the software and they helped step me through getting rid of this garbage. You should never have to install software to get a modem or router to work as any software the comes with it, is simply used to provide easier configuration.
Since I couldn't find anything about bypassing this software, I would suggest contacting Verizon directly. Their technical support should be able to assist you.
Vista is almost as bad as Verizon services. I have had a ton of problems. I had a Westell router that kept going out and then I put my Actiontec on. It was a lot faster but still drops out all the time. When I log in to the router it says I have both dsl and internet connection. and then my pc shows I have the locals only. Where I live has old wiring and Verizon won't fix there end of it.
