Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
Many Mp3 players often times have no power button, or a On/Off button. Although they probably should, many companies allow buttons to play multi tasks in the ever increasing need to save space.
Most times, pressing the play button, or holding the play button (signified by a right facing triangle) is used to start the mp3 player.
Ipod's do not have a "on?off" button either, you can simply press any button to make it start. holding the play button will allow it to go into a power save mode and "shut down" as well.
There is often a "lock" button you may have to slide or press in order to get it to turn on. This button is there so to no accidentally turn on the mp3 player when you dont need it, and waste battery life.
Hi there they say the new printers same as you got cant be reset it go to be the shop to do this but you can try this, but pleas can you come back let us know if it worked so other can use this trick, Thanks
Start with printer off
Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
While holding the Power button, release the Resume Button.
Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping. All The Best
Click the power button again - don't hold it down, just tap the on/off button. The backlight by default is shut off when the unit is powered up. To turn it on you press the power button again
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
