RIM Research In Motion Blackberry Storm 9500 Smartphone - Unlocked  Logo
Posted on Feb 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth problem my blackberry 9500 storm mobile have bluetooth problem i.e can send data but cannot receive pls help
Arshad
Level 2:
  • Expert 270 Answers
  • Posted on May 12, 2010
 Arshad
Expert
Level 2:
Answers
270
Questions
0
Helped
115269
Points
560
Hello
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
3helpful
3answers
I am locked out of my blackberry 9500 i have forgot my screen pattern and i need to reset it please help!
Enter any password until you fail 10 times, it will make your blackberry storm 9500 unlocked from old password and erase your previous data. There is no option to unlock blackberry password without loosing the data, that's feature of RIM security system. So good luck!
1helpful
Hi, i have a storm 9500. my problem is that i cant recieve any data via bluetooth. it was working properly but since i upgraded my software , it aint working anymore.. i can stil send but cant receive via...
When you open Manage connections in the MENU thers is a option SET UP BLUETOOTH then search for the open devices which are visible then pair it by using the sme pass key then when your done with pairing you go to MEDIA then when you open media and then press BB button which is the 2nd button from botton of the screen their you will see an option Recieve using Bluetooth and the screen displays waiting for connection and then you will be able to recieve any file video or piture .
2helpful
I have a blackberry storm 9500 phone, i only just got it secondhand it was on vodaphone but was unlocked to any network, the problem i have is that i can bluetooth pictures and files out but i can not...
That isn't a problem when your done with the pairing you should go to media and press the bb button their you will find recieve ussing bluetooth , you should do the same thing evry time you recieve a file or picture ,.
I have a blackberry storm and i activate my bluetooth but when i try to recieve something e.g. Music from another phone the other phone finds my bluetooth but it wont send? and when i go into manage...
Go to Media> Music>Send the Music from the phone>Press the Blackberry button on your phone>Then scroll down to Recieve File via Bluetooth.
Best regards
7helpful
Blackberry curve 8520 unable to receive files transfered from other Mobile device through bluetooth. But able to transfer data to other mobiles through blue tooth
My Blackberry curve 8520 can send data via bluetooth but it unable to receive data from another bluetooth enabled device. please send me solution.
6helpful
2answers
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
2answers
The MMS feature is not working properly
When using an unlocked phone such as the Storm on T-Mobile, you need to get T-Mobile to send the MMS settings to your phone. You can obtain these settings and instructions by calling them from a phone other than the one you need the settings for. Their number is 1-800-937-8997. Say "blackberry" in the automated system when asked what the reason is for your call and you will be connected to an agent.
7helpful
4answers
I can not receive incomming blue tooth on my blackberry 9500
from :http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB05409
[email protected]
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
