Need to transfer photos, contacts, and text messages from Samsung Blackjack SGH-i607 to my mac. I have the USB cable and SHOULD have bluetooth ability. Manual says that only way is with microsoft ActiveSync, but I don't have download disc and can't find a free mac download. I don't need to sync-- I only need a one-time transfer. Any ideas would be appreciated!
You can follow this steps for your concern: Via Memory Card 1. Remove the memory card slot cover, located on the right side of the unit. 2. Insert a microSD memory card into the memory card slot until it locks in place 2. On the SGH-i607, navigate to the folder that contains the image 3. Highlight the desired image 4. Press the right soft key for Menu 5. Select Edit (4) 6. Select Copy (2) 7. Navigate to the Storage Card using the up or down navigation keys. 8. Press the left soft key for Select.to copy the image to the memory card Via Bluetooth On the SGH-i607 1. While in standby mode, turn Bluetooth on 2. Switch the Bluetooth visibility to On On the PC 1. Connect the Bluetooth adaptor to the PC?s USB port 2. Search for Bluetooth devices 3. Select the device to pair with the PC 4. Exchange PIN code(s) on both the PC & handset to pair devices (default pass code is ?0000?) 5. Using My Bluetooth Places, select File Transfer or OBEX to view the phone?s contents 6. Copy the desired Photo file 7. Paste the file in a PC destination
2.
in place
Menu
5. Select Edit (4)
6. Select Copy (2)
SGH-i607
2. Switch the
3. Select the
5. Using My
contents
destination
Sorry to say but those are the only possible things that you can try even for your MAC, there's no third party software that you can use for this purpose.
That's a good thing to hear even if you need to purchased a software in order for you to that purpose.
Yes, a memory card might be easier, but I don't have one! My mac recognizes the phone via bluetooth and has "paired" with it but doesn't "connect" to it. Honestly, I thought that having the USB cable, the phone would just show as an icon on my desktop and I could drag and copy all of the contact, text, and photo files (there's a bunch, so I wouldn't want to do it manually). Is there software ANYwhere that I can use for my mac? Any other ideas? Thanks.
Oh well, I was able to copy my photo files to a friend's PC and
transfer data to a flash drive. FYI, I recently discovered "missing sync" software for mac users and windows-based smartphones & devices. I couldn't find a free trial version, but the $40ish bucks for the download may be worth it for prolonged use.
