I am assuming you can select water temperature on your machine. Simply hook up your pipe to the cold water feed on the machine, and leave the hot water feed alone. Always select cold water on the machine before beginning a load. If it makes you feel better, cap off the hot water inlet on the washing machine.
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
All dishwashers are suppossed to be connected to hot water. Who connected yours to cold water and why? Doesn't make any sense. Definately change it over to hot water feed.
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
