Microsoft Word 2000 for PC Logo
Posted on Feb 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to open a document with a protected password
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Feb 02, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
33758
Points
339
Give it to right password and open it.
Regards
Ashly
3helpful
2answers
I have important document protected by password.and i forget the key words,now pls helf me to open that file
Try to open password protected word document with Word Password Recovery 5.0
This Word Password Recovery program recovers Password to Open and removes Password to Open and Password to Modify easily for Microsoft Word of all versions from 97 to 2007.
source(s):unlock word password
tip
How to Break MS Word Password Protected Document?
<p>If you have read the novel "<span>The Girl with the Dragon Tattoo</span>", you must remember that there was a character said free programs were available on the web to <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"><b>break MS Word password</b></a> protected document. If you did a search then you will find that there are thousands of free download of word password breakers. All of them said MS Word document that are password protected can be opened easily with a few minutes. Is it true? This article will tell you.<br /> <p> <br /> <p>For what it's worth, it is my understanding. Microsoft Word offers three levels of password protection. These protection methods can all be used together or separately:<br /> <p> <br /> <ul> <li><b>Password to open:</b> Requires a user to enter a password to open and view the document. If the Word document was set a password to open, the entire MS Word file is encrypted with the RC4 stream cipher.</li> <li><b>Password to modify: </b>Requires a user to enter a password to read and make changes to the document. When the Word file was set a password to modify, the password can be viewed or changed with a hex editor.</li> <li><b>Read-only recommended: </b>Prompts the user to open the document as read-only if they do not need to make any changes to the content.</li></ul> <p> <br /> <p>In some case, your document was protected from editing and do not really encrypt the underlying document, so a malevolent human could open the underlying XML of the docx file and edit it directly. Other forms of password protection actually encrypt the file. If you do this kind of password protection then the file should not be opened without a password. Malicious users could still try to open the file with a variety of techniques, but it would be very difficult. Some of these techniques include:<br /> <p> <br /> <ul> <li><b>Brute force and dictionary attacking:</b> this attack basically involves the Word password breaker tool trying every possibility of every password to see if they successfully <b>break word password</b>. So the way for you to combat this attack is to set a strong password. </li> <li><b>Rainbow tables:</b> Word password breaker didn't need to know how Microsoft Word saves its encrypted file. If it were possible to get hold of the hashed password and the encryption algorithm used, a rainbow table might let you <b>break the word password</b>. </li></ul> <p> <br /> <p><b>MS Word Password Breaker</b><br /> <p><br /> SmartKey <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html">Word Password Recovery</a> is easy-to-use software designed to unlock, crack, <b>break word password</b> protected document in less than 2 minutes and all by yourself. It offers three different attack methods: brute-force attack, brute-force with mask attack and dictionary attack. This program not only can help to<a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"> <b>break word passwords</b></a> to open but passwords to modify .All Word versions are supported. It work like a charm and will never waste your time.<br /> <br /> <p><b>Related Article:</b><br /> <a href="http://recoverlostpassword.com/article/crack-word-password-with-word-password-cracker.html"><img src="jiantou.gif" /> How to Crack Word Password</a>?<br /><br /><b>Article Source:</b><br /> <a href="http://recoverlostpassword.com/article/break-word-password.html">http://recoverlostpassword.com/article/break-word-password.html</a><br /><br />
on May 06, 2011 • Computers & Internet
tip
How to Open a Password Protected Word 2003 Document?
Microsoft Word document offer password protection which allows you to protect your sensitive information containing in your Word file, then anyone who wish to access to your file should enter the correct alpha-numeric password firstly. If you cannot open a secured word 2003 document, it must be irritating, right? This article will show you three effective options to <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"><u>open a password protected word 2003 document</u></a>.<br /> <br /> <img src="open-password-protected-word-document.jpg" /><br /> <b><br /> <br /> Method 1: Using VB.NET<br /> </b><br /> <br /> The following code sample shows how to open a password protected word document using VB.NET<br /> <br /> [VB.NET CODE STARTS]<br /> Dim objWord As Object<br /> Dim strPassword as string = "PASSWORD"<br /> <br /> objWord = CreateObject("Word.Application")<br /> objWord.visible = False<br /> objWord.application.WindowState = 2<br /> objWord.application.DisplayAlerts = False<br /> <br /> Try<br /> objWord.Documents.Open("YOUR DOCUMENT FULL PATH NAME", PasswordDocument:=strPassword )<br /> Catch ex As Exception<br /> Msgbox ("Cannot open word document" ,vbExclamation , "Password Protected")<br /> End Try<br /> [VB.NET CODE ENDS]<br /> <br /> <br /> <b>Method 2: Obtain the password from the source</b><br /> <br /> <br /> The following steps sample shows how to obtain the password from the source<br /> Step 1: Check with the word document source for the password.<br /> Ask yourself where does the locked word 2003 document come from? Supposing it created by someone else, then ask the creator for the password. If your own are the word document source, you will need to locate the lost password.<br /> Step 2: Verify the password with the source.<br /> Make sure you have the right password on hand. Verify the password can save you time. The other reason to do so is that you never know they might have given you the wrong password in the first place.<br /> Step 3: Enter the correct password.<br /> Type in the correct password at the "Enter Password To Open File" dialog box. After you have entered the password, click the OK button.<br /> <br /> <b><br /> Method 3: Using password-cracking software</b><br /> <br /> <br /> If so far you still didn't solve your problem, then you'll have to go buy one of password-cracking software available for this purpose. So go to the link in "Source(s)" and download the <a href="http://www.recoverlostpassword.com/products/wordpasswordrecovery.html">word password cracker</a> program. It comes with a trial version and follows the walk through. You only need to use the program to open the locked word document, choose the type of attacks for word document with strong encryption. Then the program will start and keep running until find out the lost word password for you to open.<br /> Source(s):Good Search: <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html">SmartKey Word Password Recovery<br /> </a><br /> <br /> Keep in mind that there nothing will miss as long as you use the corresponding password to<a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"> <u>open your password protected word document</u></a>. <br /> <br /> Article Source:<a href="http://recoverlostpassword.com/article/open-password-protected-word-2003-document.html">http://www.recoverlostpassword.com/article/open-password-protected-word-2003-document.html</a> <br />
on Apr 15, 2011 • Computers & Internet
2helpful
5answers
How can open password protected microsoft word document
I recommend you three password recovery tools, anyone of which can solve your problem with great ease.
This first one is Word Password Recovery 5.0. which is specially to remove ms Word passwords including password to open and password to edit.
The second one is Office Password Unlocker, which is office password recovery kits. Including password recovery tools for ms word and ms excel.
The third one is Password Unlocker Bundles. This program is an all-in-one password recovery kit. It contains rar password recoverytool, windows password recovery tool, office password recovery tool, ms word password recoverytool, ms excel password recoverytool, winzip password recovery tool and pdf password recoverytool ,ect
5answers
Same problem!!!
Hello Ivan,
Have you tried this password recovery tool?
http://www.petri.co.il/word-password-recovery.htm
Please let me know if you are still having issues.
tip
How To Password Protect & Decrypt Microsoft Office 2010 Documents
Microsoft office 2010 , the next big buzz from Microsoft after Windows 7, is a productivity suite for Microsoft Windows,and the successor to Microsoft Office 2007.
Screenshots of Microsoft Office 2010
Not long ago I was just wrote an article about How to Password Protect Microsoft Office 2007 Documents. Now I’ll write a similar article about office 2010 by popular demand.
Microsoft Office 2010 indeed simplified the process to password protect and encrypt office documents. Which was considered a commendable improvement over password protecting documents under Office 2007. as the new process for Office 2010 is consistent across the core Office product line which including Word 2010, Excel 2010, PowerPoint 2010 etc. so here I only need to show you how the process just once using Microsoft Word 2010 as example.
Follow the step-to-step guide To Protect A Word 2010 Document Using Built-in Password Encryption
1. Click the File tab, then Click Info. On the menu to the right Click Protect Document and
Click Encrypt with Password.
2. The Encrypt Document dialog will appear, Type in a password and then Click OK to finish.
Please note – It’s very important to use a STRONG Password or Pass Phrase to protect your word document. Using a long PASS PHRASE (IE:I enjoyed myself today!) however with 10 or more characters will significantly increase the encryption strength of the document and decrease the likelihood someone will be able to break the encryption and gain access to your document.
After setting a password, your document should be protected!
Having password protected your word document? Someone should ask what if I forgot the password. So that’s what I’ll show below.
Follow the step-to-step guide To decrypt Word 2010 Document Using word password recovery 5.0
With this user guide, even a new user can fully control Word Password Recovery 5.0 in less than a minute.
Step1: Click “File>Open” in the Menu or the “Open” button to browse in the Word document.
Select your file in the Open File window, and click “Open“.
Step2: Select “Brute-force Attack (Trying All Possible Combinations)“.
Step3: Click “Start” button in the Menu to initiate the program.
Step4: The program is searching the password. Some time later, a message box pops up to you, displaying the expected password. Click “Remove All Passwords from the File” to remove all passwords (Password to Open and Password to Edit) from the file. Click “OK“.
Following this article, you could password protected your office 2010 and decrypt password protected office 2010 with ease.
on Jun 30, 2010 • Computers & Internet
tip
How to Password Protect And Access a Password-Protected Word Document
How to Password Protect a Microsoft Word Document
If you are working on documents that are important and shouldn’t be changed, then there is a way to password protect them so they cannot be changed except by you. You can also make the documents unavailable to open unless the person has the password as well.
Instructions
Things You’ll Need:
  • A Computer
  • Microsoft Office with Microsoft Word
  • Word Documents
  • General Knowledge of Microsoft Word
Step 1
Open Microsoft Word and open or create the document that you want to password protect.
Step 2
Click on “File” in the toolbar and select “Save As”.
Step 3
Click on the “Tools” menu and select “Security Options”.
Step 4
This will open a “Security Options” window. You may now set a password under the “Password to open” box, “Password to modify” box or both.
Step 5
Once you type in the password of your choosing you can opt to make the file “Read-only” by checking the appropriate box. You may then click “OK” to save your changes and then save your document as usual.
How to Access a Password-Protected Word Document
Accessing a password-protected Microsoft Word document is only possible when you have the correct password that opens the document. Encryption and security levels differ for separate versions of Word. Microsoft 2007 doesn’t offer any solutions to allow a user to retrieve forgotten passwords and Microsoft does not allow its employees to help in retrieving or breaking passwords. If you do not have the correct password for the document, you will be unable to access it.
Instructions
Things You’ll Need:
  • Microsoft Word
  • Document password
Step 1
Navigate to the location on your hard drive where you stored the Word document.
Step 2
Double-click on the document to begin opening it. A separate window will appear that prompts you to enter the document password.
Step 3
Enter the password, which is case-sensitive.
Step 4
Click the “Open” button or hit the “Enter” key. If the password was correct, the document will open. If it was not correct, another window will display advising you the password was incorrect and prompting you to try again.
Tips & Warnings:
Have you ever think of this situation, what if you forget the word password ? does that mean you’ll never regain the data in your word document, of course the answer is not , here is the solution for you to unlock password protection word document without data loss!
that is :Word Password Recovery 5.0, a simple tool for the easiest solution to Word password recovery. It recovers/removes the “Password to Open” and “Password to Edit” for you to view and edit the document freely.
By the way, there is a tool there called Password Recovery Bundle which including not only Word Password recovery 5.0 but also other programs that can recovery your windows password, office password as well as rar password, PDF Password, ZIP Password .
Related Posts
on May 07, 2010 • Computers & Internet
1helpful
Word not works
If your word dont work,it maybe your Word program might not be activated, the document might be locked for editing or password-
protected, or you might be trying to modify a document or text in a form that is protected.
you can check the article given below on Password Protect And Access a Password-Protected Word Document :
http://www.blog.recoverlostpassword.com/password-protect-and-access-a-password-protected-word-document/
Password protected document
There are programs you can download from the internet which open such documents, do a google search for "opening password protected word docs" Apart from that theres no Microsoft driven way to open this document
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
