Distinctive Ring
basicsDistinctive Ring service is an
optional service available from many telephone companies. The
Distinctive Ring service permits you to assign more than one telephone
number to the same telephone line. Distinctive Ring allows you to use a
single phone line for both voice and fax calls. You can assign a unique
phone number and ring pattern for incoming fax calls. When a fax comes
in, each telephone number makes a distinctive ringing sound, such as a
single ring, double ring, or triple ring.
NOTE:
The Distinctive Ring Service
is the name HP and others use to describe this feature. Distinctive Ring
is also known as:
The Distinctive Ring Service allows the HP
product to work similarly to a dedicated fax line.
If you connect an HP fax product and a telephone to one telephone line,
you can assign one telephone number for fax calls and another for voice
calls.
NOTE:
You cannot
send or receive faxes when the phone line is in use. Even if the HP fax
product has a separate telephone number, it is still sharing the same
phone line.
Set the Distinctive Ring
Service Using the menus on the
product control panel, follow these steps to set a distinctive ring
pattern.
Step one: Turn on Auto Answer
Turn on Auto Answer by pressing the Auto Answer
button on the control panel. The button light indicates when Auto
Answer is on.If the button light is
already on, you do not need to press the button.
Step two: Set the distinctive ring patternFollow these steps to change the answer ring
pattern.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
My HP Wireless tries to pickup non fax calls and then leaves the line open so my cordless phone will not allow me to take calls. Very frustrating as it happens often.
SOURCE: Fax rings but will not pick up or give fax tone
hmmm..that's a fax settings issue on the front panel...you may new drivers for that hp.
get them here
SOURCE: Distinctive Ring Fax Receiving
I have a brother MFC - 425CN fax machine and need to change the distinctive ring to a duet line as I have no provision for this is the manual i got with the machine.
Can you please assist
SOURCE: HP Photosmart all in one. Trouble with Telephone & fax rings
Hi Natalie,
Did you follow the instructions in your HP Photosmart 3110 AIO manual, starting on page 30? I'll assume that you set-up your printer using Case E or Case H, where you share a voice line with your fax service. If so, then you should set the AUTO ANSWER option to OFF per the instructions on page 50.
If you have an answering machine, then you should set up the printer using Case I, whereby you will set the AUTO ANSWER option to ON and then set the the RINGS TO ANSWER to a number greater than the number of rings for your answering machine to pick up.
I hope this helps. If you have another configuration that I haven't answered (i.e. other than Case E, H, or I), please reply back with your exact set-up.
Or if you have lost the manual, you can get it from this website:
http://h10032.www1.hp.com/ctg/Manual/c00485549.pdf
If you found this answer useful, I would appreciate you leaving feedback.
Thanks,
Lee
SOURCE: where is the fax set up to tell the J3680 not to answer automatic
i fixed the fax set up (from the machine itself) to answer a fax on the triple distinctive ring. we don't have that on our phone service, but this way, i can change it back to a single ring if i'm expecting a fax.
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings section.
