Timex Expedition Camouflage 40691 Wrist Watch Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
HOW DO I CHANGE THE BATTERY AND RESET THE TIME ON MY TIMEX 40691 EXPEDITION
Anonymous
Level 3:
  • Master 714 Answers
  • Posted on Mar 14, 2010
Anonymous
Master
Level 3:
Answers
714
Questions
Helped
316778
Points
1893
Http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 • Watches
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
I have a Timex Expedition and I use the automatic restart timer for work. When I got the battery changed I no longer had the feature. I have to reset each time.
If you haven't got any instructions you can get a copy from their web site.
If you have instructions and they are of not help, I suggest that you contact Timex and tell them of your problem.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
How do I reset the time on a timex 40691
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope this tip helps
R/
David
After replacing battery, the watch does not
I found and pressed the reset button with a tiny screw driver. After about 10 attempts, I pressed the function side button and found that date and time displayed temporarily while holding button down.
Finally after more reset attempts, the time did display.
I have a Timex expedition chronograh. Every thin
The nice thing about Timex is they have a 12 month warranty that covers just about everything. If you have had the watch longer....
Get the batteries checked. Battery life is typically about 2 years.
If the battery is fine then you can try having the watch reset but in most cases the LCD board or circuit board is damaged the watch has to be replaced to have it function correctly.
9helpful
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
5helpful
3answers
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
