Clark Forklift Horn Button Switch  , Cat Etc Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with Clark forklift TMX12-25 TMX250, red spanner warning lights come up. whats that mean, how to reset it
Edwin Maclen
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 25, 2013
Edwin Maclen
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
2896
Points
15
That's not only problem in clark forklift. Such type of problem is happened in most of forklift after long time. If you want to solve your problem, then consult with forklift repairer. If you want to buy a new or used forklift truck, then visit http://www.biondorentals.com.au/ .
Anonymous
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Feb 01, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
111
Questions
Helped
40427
Points
299
It means it's time for your periodic maintenance, the reset button should be close to hour meter
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 28, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1176
Points
HOW TO CLEAR CODE CANBUS ERROR 2 ON CLARK FORKLIFT?
I have clark forklift not starting
error: canbus error 1
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
5helpful
Ford Transit warning light.
red spanner means van is due for a service. You can turn it off yourself by turning ignition key to position 2 and then holding down the brake and clutch pedals at the same time til the light flashes then goes out. Should take about 15 seconds.
Why does my clark forklift lower by it self
it has bypass in the cylinders you need to rebuild it[put new seals in it].
Make, Model, & Year of Clark Forklift
Contact a Clark Dealer or service center. They can trace the chassis numbers. Don't run it without a plate on it, it's illegal and totally uninsurable.
2answers
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when...
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
Top Clark Electrical Supplies Experts
Aron
Don A
Don A
Simon Atkinson
Simon Atkinson
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
