If I dail the number 1 key to listen to my voicemail, i hear my own message and could infact leave myself a message. I do not go through to the mailbox. Its ok if i dial 121.
Hi there penny yes i was about to say dial 121 thatll take you straight to your message inbox voicemail box or ring your servic provider and get them to go through step by step with your voicemail settings hope this helps and if you have time please rate me
thanks again
Delete voice mail by going through the keypad on your cell phone. The actual procedure depends on the kind of cell phone that you own. For example, on the Nokia 1100, hold down the "1" key while you are on standby. Tracfone connects you to your voicemail, where you can follow spoken menu instructions to listen to your voicemail. After you hear the voice message, you're asked if you want to delete your recordings.
This is not recommended, because connecting in this way uses up your minutes even if you just want to listen to them.
Use your landline phone to delete messages if you want to avoid using your Tracfone minutes. Turn off your cell phone so it doesn't ring and then call your cell phone number from a landline.
Press the "*" (star) key as soon as you hear your voice mail greeting. Then enter your password number and press the "#" (pound) key.
Listen to the instructions for accessing your voice mail, which can vary slightly depending on the phone you have. You are told the number of new and old messages you have, how to listen to them and how to store or delete them. Press the number for listening to the message to hear it, and then the number for deleting.
just dial your voicemail box number to listen to voicemail messages left by callers..usually the #1 key is the voicemail dail key..press and hold the #1 key to have your phone dial the voicemail number..(if voicemail is activated and set up on your phone)
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
this will depend on who your network provider is. They have there own num,ber you will need to dail or sometime if you hold the 1 key down it will take you to voice mail.
Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
FYI... Voicemail is free no need to subscribe to (its your option to turn on or off)... press and hold down "1" key on cell or dial your cell phone number..once the answer machine starts press the "*" key...listen to options or if messages begin to play (while playing press "7" to delete)...in options you can choose to fwd calls, or not to plus other features...
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
Setting Up Your Voice Mail from page 10 in your manual: Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail 1. In idle mode, press and hold the key or dial your own mobile number to dial voice mail. After connecting, you will hear your voice greeting. 2. Interrupt your greeting by pressing . 3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time. JimmyC
The phone you have can go on several different Norstar phone systems and you can have several different types of voice mail. Your voice mail (and possibly the phone system) needs to have programming changes, not the telephone. Your first step is to determine which Nortel phone system you have and also what model voice mail. You will need manuals for the phone system and voice mail. Hopefully you already have a programming or administration manual for the voice mail. Someone should have gotten this information when the system was first installed but that could have been many years ago.
What happens when you are waiting for that time? Do you hear absolutely nothing? Instead of being sent directly to your voice mail box, it may be sending callers to a voice mail branch where you would normally have a recording "press 1 for this, 2 for that" If there is no recording the system will wait for a response that the caller has no idea of and usually replay the message 3 times before defaulting to your mailbox (in this case a blank message). That is my best guess with the information I have from you so far.
