Can it be repaired?
You can replace the screen itself. All you need is a small phillips screwdriver and a small flat screw driver. Take off the two screw (one is underneath the battery). Then there are eight tabs that go around the side. Push in on those and pry the remote apart. Then there is two more screws you have to remove. Then if you pull the board off after you disconnect the charging cable. The screen has a cable that goes to the motherboard that is held on by a plastic piece. Remove that plastic piece and your LCD is off. Installing a new is reverse of removal. Hope this helps. It literally takes 5 minutes to remove it.
No, it cant be repaird, you are going to have to contact logitech to see what they can do for you. you also cant get any replacement PARTS. your going to have to get the whole remote replaced or get an out of warranty coupon which gives you 50% off harmony remotes on the Logitech website
