Question about LG WM-0532HW Front Load Washer
OE for LG WM-0532HW - LG WM-0532HW Front Load Washer
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
6ya staff
SOURCE:
Lg front loader washer WM 0532HW doesn't spray water anymore
u could try running a cycle or two with a mixture of 1 part vinagar to 3 parts water and see if it cleans out use hot water
Feb 26, 2013 | LG WM-0532HW Front Load Washer
What is a code OE
Oe code is a long drain error or no drain remove the pump check if there is something in it if not replace pump
Oct 07, 2012 | LG WM-0532HW Front Load Washer
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
Washer get to rinse cycle then reads OE on the
OE means OUTLET ERROR. If you have water in the machine, you can either drain the water using the small hose inside the lint filter door(bottom right hand side), removing the end cap. A second, and quicker method, is to lean the machine up against the rear wall at approximately 45 degree angle(TAKE CARE to secure), unscrew the lint filter cap, looking down the barrel you will most likely find: a coin(s), wire, rubber band(around impellor) etc. If your pump is unusually noisy, one of these items will have damaged the pump. ALWAYS take care checking clothing for these items before placing in washing machine as bowl damage is costly and NOT covered by warranty.
May 05, 2010 | LG WM-0532HW Front Load Washer
I keep getting an error OE on my LG WM0532HM front load washing machine and it won't spin out the water, just stops after a few minutes
The OE error is "Outlet Error" for the draining the water from the unit.
The unit is having trouble draining the water from the unit and that is why there is an error code.
You need to be sure there is nothing in the pump's filter (located at the bottom left on the front panel) that is restricting the water's flow.
If the pump's filter and housing is clear then it is the pump that has or is going bad.
The pump will fail because a seal will let water into the back side of the motor and case it to lock up.
If you need a part number for the drain pump, let me know.
Apr 24, 2010 | LG WM-0532HW Front Load Washer
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Mar 19, 2009 | LG WM-0532HW Front Load Washer
Too much soap?
if the washer is draining ok if not you will need to ck the drain pump. i hope you useing the he sope if not you need to switch to he sope . try to do the above . and get back with me thanks.
Apr 06, 2008 | LG WM-0532HW Front Load Washer
Washing Machines Logo
267 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
