V750 Motorola will not ring for incoming calls only viberates when set to "ring & vibe" setting. When setting or changing a ring tone I can hear the ring tones emitting from the speaker
Check that these people who are calling, in your phonebook, do not have a picture or are edited. Delete them from your phonebook and then add them again. I had this problem today and solved it using this method :)
You've probably already tried these, but what the heck; you asked...
1) Check in MENU -> SETTINGS & TOOLS -> SOUND SETTINGS -> CALL SOUNDS -> CALL RINGTONE to make sure that you have actually selected a ringtone instead of the "No Ring" option at the bottom.
2) With the phone open, try the up/down buttons on the left-hand side of the phone (above the Push-To-Talk button) to make sure that your volume isn't set to "All Sounds Off," "Alarm Only," or "Vibrate Only." It has to be at least at "Low" before a ringtone will play.
Hope this helps. If not, you probably need to take it in to a Verizon store for an expert assessment; they'll usually take a look at your phone and install any software updates for free.
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
