Canon Pixma MX700:one print head--the magenta one--not printing. Have replaced it two times with new ones and it doesn't say that it's NOT there, but doesn't deliver any ink. Have tried "cleaning" under maintenance. It's like the print cartridge is just not getting a signal to fire away...
The cartridge is only a tank that holds ink. The printhead is the device that you put it into and probably has a blockage in the magenta head. Open the machine so the carriage moves to the center. remove all the cartridges.
TCT How to remove and clean Canon Printhead see the link below. The MX700 may have the locking mechanism at the front of the carriage, so you should move it slightly right and then pull the colour bar forward to release the printhead. carefully remove the printhead. Sit it in a shallow dish/tray of hot water for a few minutes and dry with a paper towel. Put it back in the printer reset the locking bar and cartridges. Try a nozzle check through the tools menu. Yoyu may need to repeat the process if the magenta printhead is badly blocked
SOURCE: Color ink cartridge does not print in full colors
Canon printers do not like the refilled ink cartridges. After having ruined a few printers trying to "save" money. I went back to genuine Canon ink and have never had a problem since.
SOURCE: one color is not printing properly ( magenta )
use a qtip and clean teh wipeoff area where the cartridge goes...
that and clean all around where the stripe may develop...
SOURCE: how to refill pixma mx700 magenta ink tank without
The colors are individual. That machine takes the Canon CLI-8. I would suggest reading your manual on what the procedure is for changing the ink cartridges out, it typically varies slightly by machine. There should be an option somewhere one of the menus to change the ink cartridges. When you buy a replacement be sure you buy from someone who isn't trying to scam you. I would recommend Cartridge World, of course, or OEM. Do not use cheap online cartridges, you will only have headache later.
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
SOURCE: I have a Pixma IP4200 that the Magenta(M) cannot
click on start button then click on control pannel and then right click on the printers and select the printer options fom the drop down menu
