Creative Labs ZEN V Plus MP3 Player Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer running under Windows XP says my device is not connected and yet it shows in Windows explorer?
Aravindhan Venkataramanan
Level 2:
Novelist:
  • Expert 136 Answers
  • Posted on Jan 30, 2010
Expert
Level 2:
Novelist:
Answers
136
Questions
Helped
50375
Points
423
Hi There..
When you say device is listed in windows explorer, butif the XP says device is not connected. Then i'd say the device is detecting as storage media (i.e MSC).
It needs to be connected as MTP. In this case i'd request you to update the MTP driver.
To update the MTP driver you can try two ways.
First Step:
1) When you connect the MP3 player to the computer you could see a SAFETY REMOVE HARDWARE on the system tray.
2) Right click on that safety remove hardware.
3) You will get a popup, in which you need to click on properties
4) That will bring the window in which you can see your MP3 player listed.
5) Right click on it and choose the option update driver.
6) This will update the MTP driver of the player and after that unplug the device
7) Restart the computer and now connect the device.
8) That will automatically update the drivers.
SECOND METHOD:
1) Go to device manager
2) Locate for the option that says USB and right click on it.
3) Try updating the drivers.
4) Now restart the computer.
5) That should work.
Kindly revert if you have any clarifications.
How can I connect my computer to a wifi hotspot I have a Linksys AE 1200 Wireless-n- USB adapter that I installed and it shows that I am connectted but when I try to open internet explorer it says I a
It seems like you are missing the CD you need to fully install this adapter. However, you still can download this data at this link. Since you have Windows XP, click the download link under where it reads 'XP Driver'. Feel free to respond if you need further help.
1helpful
2answers
I have a WD2500 installed in an external drive enclosure connected to my comp. running XP. I have the jumper on cable select. It is connected via USB. When I turn the enclosure on, the drive spins up, and...
Please check if your HDD is visible in storage management. You must be logged on as Administrator or as a member of the Administrators group view and modify most properties and perform most computer-management tasks.
To start and use Computer Management on the local computer:
  1. Click Start, and then click Control Panel. Click Performance and Maintenance, click Administrative Tools, and then double-click Computer Management.
    The Computer Management window for the local computer is displayed. "Computer Management (Local)" is displayed at the root of the console tree.
  2. In the console tree, expand System Tools, Storage
Then check if your USB HDD is visible under one of next options. This is for windows XP.
If it will be presented there try to right click on this drive and format hard drive. Also please recheck your jumper position. This picture might be very useful c33351b.gif
1helpful
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win...
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
I dont have the manual my MP3 104 came with because it was a gift but how can I get my computer to recognize it again Correction: Archos 104
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
Next:-- Refresh the driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. NOTE: - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Next - Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. ffffff
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
Pendrive not showing in vista explorer
Hi!!
Right click on my Computer
Select Properties
Hardware devices
Device Manager :
Check your USB port.. whether everything is connected.
If its shows yellow mark means re-installing the device driver or to update it.(install by ur motherboard cd)..
bye...:)
Strange situation that I am getting annoyed with. Here's what the deal is: I have a Wireless MS Intellimouse Explorer which actually works fine but, the intellipoint software (nor device manager) does...
Sounds like you need to update your mouse's driver, you will find the intellimouse 6.3 driver for Windows XP at the link below "IntelliPoint 6.3 32-bit for Windows XP".
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=MK&type=Mouse&name=m_imobt&os=XPSP2&lang=en
Can't find clip in my computer
This is and excerpt from "EphMusicFan" on the Real player forum. Original link is also below.
" The following steps finally fixed everything for me. While it may seem long, it only takes about 15 minutes and should fix everything.
If you run windows XP don't have Windows Media Player 11 installed, download and install it here,
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
Run Windows Update, and install all high priority and optional updates related to Windows Media Player or device synchronization.
On XP, the updates include:
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows Media Player 11 for Windows XP (KB939683)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Open Rhapsody
From 'My Account' menu select de-authorize computer
Close Rhapsody
To delete the mcs.rma file:
1. Close RealPlayer/Rhapsody
2. Click the Windows Start button. Then click Run.
3. Type %windir%\system32\ and click OK.
4. Find the mcs.rma file.
5. Right-click mcs.rma and select Delete.
6. Close the window.
To delete the basi3260.dll file:
1. Open the My Computer icon on your desktop.
2. Open the C: drive (usually Local Disk (C:\)).
3. Open the Program Files folder.
4. Open the Common Files folder.
5. Open the Real folder.
6. Open the Plugins folder.
7. Find the basi3260.dll file.
8. Right-click basi3260.dll and select Delete.
9. Close the window.
10. Restart your computer.
on sansa Clip itself, disconnected from computer, go to settings, then choose format
Make sure Rhapsody, Windows Media Player, and all other media programs are closed
download firmware
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=2946 (make sure you get 'Americas' firmware version)
unzip firmware file
connect to computer
drag firmware file onto sansa Clip icon in Windows explorer
wait to finish all copying (Sansa Clip screen will say connected, not writing or reading)
disconect
firmware updates on device, then it shuts off automatically
turn it back on
reformat from device (settings menu, format)
put in msc (under USB mode on settings menu)
reconect
open sansa Clip E:/ in Windows explorer, delete all files (should be 6-8 folders and files in top level directory of Clip)
reformat from windows explorer (right click, format, (FAT file system, NOT FAT32))
disconect
put in mtp (under USB mode on settings menu)
Open Rhapsody
It will run through quick setup again, due to files deleted before.
'Reathorize Computer' (under 'My Account' menu)
"Update Track Licenses' (same menu)
connect to computer
wait for Rhapsody to fully load clip (may take 30 seconds)
reformat from rhapsody (right click on sansa clip icon in rhapsody, select reformat)
hold down control and shift buttons at same time, right click on sansa clip icon in Rhapsody, select 'reset secure clock'
right click on sansa clip icon in rhapsody, select authorize device
wait while sansa clip updates (wait for screen of device to say 'connected' for a while, rather than writing or reading)
disconect
reconnect
wait a while updates finish
disconect
verify acount, and dates on device, under setting menu, account
should say renewed (with today's date) expires a date 30 days later.
download one new track from rhapsody you never have downloaded before
reconect
transfer that one track to clip
wait for all updates to finish
disconect
verify account, dates on device, check that the track plays properly"
Hope that helps.
http://real.lithium.com/real/board/message?board.id=InstallingRhapsody&thread.id=26724
Windows Media player will not "Connect a Device"
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer.What i would recommend you to do is to uninstall the device andreinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardwarethen device manager...look for the sansa device..it usually locatedunder portable device..if its not showing there i would recommend youto look for under disk drivesand see if its there..right click on the device and click onuninstall...after you unintall it unplug your device from thecomputer....Then follow this link below to downloadthe portingkit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en.Then check the mode of yuor device to make sure it sunder MTP notmsc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows mediaplayer click on tools, options and click under privacy...clear thehistory and caches...after you finish you can plug the device on theback of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media playerto 11 even though you have done that already..and try to reconnect yourdevice..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
4helpful
6answers
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
