EliteGroup K7SOM (K7SOM W/CPU) Motherboard Logo
Anonymous Posted on Jan 30, 2010
What cpu can I upgrade to using my K7SOM+ motherboard? curently using AMD Athlon 1800.
Anonymous
Level 3:
President:
  • Master 2,351 Answers
  • Posted on Jan 30, 2010
Anonymous
Master
Level 3:
President:
Answers
2351
Questions
Helped
1590998
Points
6609
Provided below is a list of all supported CPUs for you're motherboard from ECS; http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=316&MenuID=69&LanID=0
The highest CPU is:
AMD Athlon XP 2600+ (.13u) (256K,266,Socket 462)
Cheers'
Mike
Testimonial: "Thanks for the info..I'll get one."
1helpful
Upgrade CPU on Matsonic MS8147C+
Unfortunately I think the Athlon XP is a 462 pin package and the MS8147C+ has a SocketA/Socket 462 socket for the CPU. The Athlon 64 3800+ is a 940 pin package and requires a AM2 socket, so this CPU will not physically fit.
DOES K7SOM MOTHERBOARD UPGRADABLE?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=79#Download-2
And the + versions:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=K7SOM+
I would say no because the cpu does not exist anymore.
The only thing you can upgrade is the harddrive and the ram module.
The mainboard uses SDram and DDR ram in there own seperate block.
Sdram is hard to find and expensive.
DDRram can still be bought.
The specifications:
PROCESSORS
462 pin Socket A supports the AMD K7 processors
Full series of Athlon XP/Athlon/Duron processors
CHIPSET
SiS 740 & SiS 961/962 Chipset
SiS 740 Host/Memory controller with high quality 3D graphic accelerator
SiS 961/961B/962 MuTIOL Media I/O
Integrated USB 2.0 host controller in SiS 962
LPC I/O -ITE8705F
LAN: MAC integrated in SiS 961/961B/962 and PHY on board
AC97 Audio Codec: Compliant with AC97 2.2 specification
SYSTEM BIOS
AMI 2MB Flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, Multi Boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB (DDR SDRAM or SDRAM)
I/O INTERFACE
Hope this was helpfull
2helpful
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
1helpful
3answers
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
4helpful
2answers
Can u upgrade the processorto anything high then a amd duron(tm) 1.29ghz
On this motherboard you can use:
AMD Athlon (Highest being the Athlon 1400C running at 1.4GHz)
AMD Duron (Highest being the Duron 1800 running at 1.8GHz)
AMD Athlon XP (Highest being the Athlon XP 3200+ running at 2.3GHz)
AMD Athlon MP (Highest being the Athlon MP 2800+ running at 2.1GHz)
AMD Sempron (Highest being the Sempron 3300+ running at 2.2GHz)
5helpful
2answers
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
3helpful
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
K133ASA via Apollo motherboard cpu upgrde
Socket A/462 can take any AMD K7 family processor. The fastest you could get would be the Athlon XP 3200 I believe, but that could also include the Athlon 1400 and the Duron 1800. So it looks like you can make a significant upgrade of yhe processor.
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
1helpful
K7VT2 with a AMD Duron 1.30 GHz CPU.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
